Results 1 to 6 of 6
Thread: Iron filter refurbishment?
    DIY Junior Member JMTFARMS's Avatar
    Sep 2013
    Missouri
    Default Iron filter refurbishment?
    We have a Macclean iron filter that is 20+ years old. Media has never been changed. Controller/timer has gears stripped and is in need of a rebuild or replacement. Tank seems to be in good condition (looking from outside). Filter has not been used for over a year. Backwash function has been done manually for 10+ years (using pliers and screwdriver to position piston). Hydrocharger leaks and is dirty but still functions.
    I guess we should replace media and controller.
    Are parts or replacement controller still available?
    Is it worth rebuilding (vs. new filter)?
    Ours was a model NF1001M
    Thanks for any input.
    Nov 2010
    Maine
    D you really want to rebuild a 20 year old valve and rebel the tank? If its in as bad condition as you describe your best bet is to replace the entire unit.
    Sep 2013
    Missouri
    Priced a new controller at $300 several years ago. Media replacement and labor rough estimate at $200. Entire new syis probably $1100+. $500 to $600+ savings is making me consider rebuild.
    What I don't know is if the tank, riser, bypass valve, and other parts will hold up long enough to rebuild.
    Also don't know if I can still find the Macclean controller.
    Nov 2010
    Maine
    The tank should be fine. The distributor tube should be replaced to match the new valve. McClain is still in business. Mcclain used Autotrol IIRC but it might have been Fleck too, either way though you can get a new Fleck head of your choice, and I recommend a metered valve like the Fleck 7000SXT that should fit your tank. I say should fit because tanks aint all the same. The new valve will most likely require a new bypass although you can fabricate one if you have the skills. You will want to take your old head off and measure the tank. Essentially though when you get done all you save is the cost of the resin tank.
    Sep 2013
    Missouri
    The cover on our controller said it is a Macclean. Manual just calls it a NF series Chem-Free Iron Removal System. It was manufactured by Chemical Engineering Corp.. I suspect it was sold under more than one name. Web site for Macclean and Chemical Engineering Corp. are no longer active.
    Found an ad for a new Fleck 5600 w/tank, media, and bypass for $439.00 w/free shipping. That sounds like a good deal to me. Ad is from Discount Water Softeners 176 Detroit Street Suite #13 Cary, IL 60013. Can anyone recommend this company?
    The Fleck 5600 looks very similar to our controller. Our controller had metal on plastic gears that did not last long. Is the Fleck 5600 better made?
    Also what benefits would the Fleck 7000 SXT have?
    Thanks.
    Sep 2013
    Quote Originally Posted by JMTFARMS View Post
    I ordered their "Eliminator" from them, and it works great.
  1. Iron pre-filter for RO
    By OldBat in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-10-2013, 10:09 PM
  2. Need advice for iron filter
    By AngryBill in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-31-2012, 07:24 PM
  3. Iron Filter Spews Iron after Outdoor Sprinklers are ran
    By branjo101 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-30-2011, 12:13 PM
  4. Help w/iron H2S filter
    By Nat in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-18-2011, 04:26 PM
  5. .41 ppm iron, filter needed?
    By ugabulldog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-17-2010, 11:33 AM
