We are doing a bathroom remodel. The old bathroom tapped into the existing circuit through a wall plug to power the vanity light and an oulet. The exisiting circuit is on a 15amp fuse and powers 5 wall outlets and 4 overhead lights. We spliced into the circuit, in a junction box, 4 ways. I connected all neutral wires, hot wires and ground wires (pigtailed to grounding screw). We are using 14/2 Romex as is used previously. We led one wire from this junction to a GFCI which worked fine. We led the other 3 wires into a switch box and connected 3 switches - 2 dimmers (single-pole) and 1 regular switch. We ran a wire from the first Halo recessed pot light (neutral to neutral, hot to hot, gound to ground) and connected it to the dimmer switch (neutral to neutral. hot to hot hot to hot and ground to ground to pigtail and grounding screw.) NO LUCK! I followed all the diagrams exactly to no avail. All I know is that my tester shows current running to where I have wired it but it wont work. I pressed TEST on the GFCI and it cut power to all the other wires. HELP!!!!!!! I know I'm missing something but can't for the life of me figure out what!
Thanks in advance,
Casey
Thanks in advance,
Casey
