Results 1 to 8 of 8
Thread: Kohler Adair vs Cimarron 1 piece toilets.
    DIY Junior Member lindseybp's Avatar
    Mar 2013
    Default Kohler Adair vs Cimarron 1 piece toilets.
    We are adding a small powder room on our first floor and trying to decide on a toilet. We are down to deciding between the Kohler Adair and the Kohler Cimarron, both in the one piece, 1.28gpf....never had one of these 1.28gpf toilets but I'm assuming they are fine. Outside of the aesthetic differences the main functional differences seem to be these: the Adair has "class 5" flushing technology. The Cimarron has "Aqua piston" flush technology. Is one of these better than the other? Also it looks like the Adair has >=1000map and the Cimarron has >=800map. I don't know if this makes any difference as I am not that familiar with the "map" definition. We have considered a Toto but have not been able to see that many in person. We did see a Vespin 2 and another one or two at a supply store, I think one had the "dual cyclone" flush technology. Realistically would there be much of a difference between the two Kohlers we are looking at and a Toto? Ideally I want something that won't clog easily and is fairly quiet as the powder room is very close to where people will be. Any comments or thoughts would be greatly appreciated. Thanks.
    Yakima WA
    Except for one individual that frequents this forum, most of us prefer the Toto toilets. The Vespin is an excellent model, and Dual Cyclone flush is outstanding. Mapp ratings are very overrated. It's like horsepower in automobiles, after a certain point, more becomes just hype. A clogged Toto is almost unheard of. Most of us Toto owners don't even have a plunger. Kohler's flush technology has been changed so many times, it's impossible to keep up. Seems to me, if they ever had a good one, they'd stay with it. Toto uses off the shelf parts, so when replacement is necessary, any hardware store or plumbing shop has them. All low flush toilets tend to make a bit of noise when flushed since rapid release of the tank water is necessary to accomplish the flush. However, the noise is brief because of the relatively small amount of water involved. Pressure assisted toilets are the exception because of the extreme pressure involved. (Toto does not make a pressure assist toilet)
    The two Kohler models mentioned will work. I give an edge to the TOTO II series.
    But any of these will be better than previous bowls you have used.
    The two Kohler models are pretty similar. In this case, it's a matter of picking a style you like when the decision is that close between the two.
    Mar 2013
    Reconsidering Kohler and strongly considering Toto Vespin II. Is that a good choice for a Toto?
    Yakima WA
    Excellent choice.
    Apr 2012
    New York, NY
    Absolutely. If you have a standard 12" rough-in, its sister toilet, the Drake II (model no. cst454cefg), has the same tank and same bowl, with the exception that the bowl on the Vespin II is "skirted" (i.e. the trapway is covered) and the Drake II is not. The Drake II is a little less-expensive. Because of its performance, quality, and appearance, the Drake II is one of Toto's most popular toilets. The Vespin II will perform the same.
    Drake II:
    Vespin II:
    Mar 2013
    Thanks to all for the help. Wife likes skirted so we went ahead and purchased a vespin II today and are having it installed this week.
    Apr 2012
    New York, NY
    Quote Originally Posted by lindseybp View Post
    Fantastic! Based on my own personal experience, you're going to love it. Let us know.
  1. Kohler Cimarron 3609 or Kohler Cimarron 3589?
    By pbishopp in forum Toilet Forum discussions
    Last Post: 02-08-2012, 12:25 PM
  2. Need bidet seat for Kohler Cimarron one-piece
    By GreenTree in forum Toilet Forum discussions
    Last Post: 06-19-2008, 09:56 AM
  3. Cimarron Kohler one piece model 3489-0
    By mrick in forum Toilet Forum discussions
    Last Post: 04-16-2008, 05:22 PM
  4. Kohler one piece Rialto toilets
    By JPKatz in forum Toilet Forum discussions
    Last Post: 11-01-2007, 08:35 PM
  5. Kohler 1 piece Memoirs and Portrait toilets
    By tilermike in forum Toilet Forum discussions
    Last Post: 03-09-2005, 03:36 PM
