Results 1 to 2 of 2
Thread: Well Pump Stuck on PVC Pipe
    DIY Junior Member Eldonw's Avatar
    Sep 2013
    Indiana
    Default Well Pump Stuck on PVC Pipe
    I removed the pump from the well and it is screwed into the pvc pipe. It seems to be stuck and I am afraid that I will damage it.
    What is the best or proper way to remove the old pump from the pvc pipe. It seems to have a plastic nut.
    Thanks for your help and I would not even be this far without the help of this forum.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Looks like schedule 80 drop pipe, then a plastic bushing which is screwed into the pump.
    Don't worry about damaging the pipe, simply unscrew it out of the bushing, you don't want to use that bushing again anyway..
  1. how to remove plastic pipe stuck inside copper pipe
    By libinius in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2012, 10:16 AM
  2. Stuck pump, any way to cut the pipe above the pump?
    By ncgeo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-11-2010, 10:43 PM
  3. Washer stuck to copper pipe
    By bertie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-21-2009, 11:06 AM
  4. Drain pipe stuck in wall...
    By bbbluueyes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2008, 06:45 AM
  5. dropped pipe in well and it's stuck
    By Gerald in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-10-2006, 06:21 AM
