Results 1 to 2 of 2
Thread: Rainbird ESP-M Controller Problem???
    DIY Junior Member etsherman's Avatar
    Dec 2010
    United States
    Default Rainbird ESP-M Controller Problem???
    I have a 7 station ESP-M controller that has 4 stations on the main module and 3 stations on an expansion module. All has been working correctly for the past few years until recently. The problem is with the last station #7 on the expansion module. The controller will advance to this station, start the countdown but it seems like the valve tries to open (spray heads squirts water) but that's it. It never comes on. However, I can manually advance to controller to station #7 and it will work correctly. Also, I can switch station 7 with station 6 and station 7 will come on in place of 6.
    Is the problem the controller itself or just the module will need to be replaced???
    Thanks,
    DIY Junior Member Cameron Wishart's Avatar
    Feb 2014
    Okanagan
    Quote Originally Posted by etsherman View Post
    If you are able to run the station thru the controller manually the station & module are functional. If the zone operates properly on a different station, you know the valve & circuit is functional.
    Sounds like it could be a scheduling issue if it only malfunctions.
    I would check the runtime for station #7 in all programs (A,B,C,D). If that does not resolve the issue, try resetting the controller (typically with something small on the back of the faceplate) and reprogramming.
  1. Rainbird 32SA problem
    By rikmoor in forum Irrigation / Sprinkler Forum
    Last Post: 05-28-2012, 04:01 PM
  2. Rainbird valve problem
    By leeelson in forum Irrigation / Sprinkler Forum
    Last Post: 03-24-2010, 02:19 PM
  3. RainBird Problem re Multiple Starts in a Zone
    By Sherm in forum Irrigation / Sprinkler Forum
    Last Post: 04-10-2008, 07:03 PM
  4. A strange problem with Rainbird system
    By Frankish Knight in forum Irrigation / Sprinkler Forum
    Last Post: 05-08-2007, 10:24 AM
  5. Will new controller solve problem?
    By mijway in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-11-2006, 03:35 PM
