Results 1 to 11 of 11
Thread: GE water heater controller voltage
    DIY Junior Member KeithR's Avatar
    Sep 2013
    Ontario
    Default GE water heater controller voltage
    I have a 40 gal GE "Profile" "Smart" water heater, about 5 to 7 years old.
    Trying to trouble shoot shortage of HW,and discover voltage to the top element is 240v, but the bottom element is only getting 120V.
    Do I need to replace the top controller which feeds to the bottom one or is it meant to do this?
    Mar 2011
    Houston, TX
    Quote Originally Posted by KeithR View Post
    What is your Model Number ?
    Good Luck.
    Sep 2013
    Ontario
    Its a PE40T9CB00
    Actually closer to 10 years old.
    Sep 2013
    Ontario
    I think I need to study it a bit closer before jumping to conclusions. My first observation was with wires disconnected from both elements. I drained and re-fillled the tank.
    Now with the top element connected, there is zero voltage at the bottom element. Does the controller cycle back and forth so only one element is on at a time?
    Mar 2011
    Houston, TX
    Normally, Yes it does work that way.
    Did you have power off when you drained it ?
    Sep 2013
    Ontario
    OH yes!
    I just checked resistance. Top is 20K ohms & bottom is 7K ohms. (They are supposed to be the same!)
    Both are infinity to ground.
    Sep 2013
    Ontario
    So two new elements and we have hot again! Thanks for comments Rocket Scientist
    Mar 2011
    Houston, TX
    Good Deal.
    Enjoy.
    An element will ONLY register 120 v. when it is burned out. It also does not heat when that happens so only the upper element operates to heat the water at the top of the tank, giving you a short supply.
    Mar 2011
    Houston, TX
    Sounds like both elements were Open. If the posted readings are correct.
    That is a bit strange, unless power was applied with no water in the tank. Or one element has been bad for awhile.
    DIY Junior Member kahnman's Avatar
    Sep 2013
    Ontario
    Hi Keith. I am having the same problem with my exact same model water heater. I did a search of the model on the GE support and parts site and no results. Do you still have the element part numbers and where you ordered them from? Thanks.
  1. Flickering lights on circuit with low voltage and line voltage bulbs
    By davidwie in forum Electrical Forum discussion & Blog
    Last Post: 04-18-2011, 07:34 AM
  2. Wall Socket With Voltage AND No Voltage? HELP!
    By jackvogel in forum Electrical Forum discussion & Blog
    Last Post: 12-23-2010, 07:41 AM
  3. Reseting my Franklin Controller often, water shutting off
    By mrmike in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2009, 08:13 AM
  4. CP Water Controller
    By haysie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-21-2009, 07:28 AM
  5. Running low voltage in high voltage boxes
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-22-2009, 07:27 PM
