Results 1 to 1 of 1
Thread: New 64k 7000sxt Install Requires Proper Values Before Starting up
    DIY Junior Member Smokerman's Avatar
    Sep 2013
    MI
    Default New 64k 7000sxt Install Requires Proper Values Before Starting up
    I could really use some help with start up - what are the best settings for my application? I haven't input or filled anything. I have read many posts where the poster had to perform multiple backwash's to correct start up issues...
    Here are my specs:
    * 2600 sq ft House (Just built)
    * 3/4" (7/8" OD) PEX Tubing Main feeding my header valve which then has 1/2" PEX feeding house. Each appliance has its own shut off valve at the header.
    * 3/4" PEX Water Softener Prep
    * 2 Full, 1 half bath (No jetted/deep tubes & no body sprayers)
    * 4 people (2 adults, 1 teenager, and a 10yr old)
    * Average water use
    Community Well water:
    Arsenic: 10ppb (billion)
    Fluoride: 4ppm
    Hardness: 17gpg
    iron: .3 ppm
    Nitrate: 10ppm
    Nitrite: 1ppm
    Sulfate: 0ppm
    Sodium : 38mg/l
    Total Trihalomethanes: 80ppb (billion)
    Total Haloacetic Acids: 60ppb (billion)
    Chlorine: .2ppm
    Lead: 1.5ppb (billion)
    Copper: 1.3 ppm
    Flow Test 7.32gpm (41 secs to fill 5 gal bucket)
    Any and all help much appreciated!!!
  1. Recommendations for proper way to install expansion tank with new water heater
    By DoofusOfTheDay in forum Water Heater Forum, Tanks
    Last Post: 08-18-2011, 07:33 AM
  2. Improperly installed DW - Air gap. Permanent damage? Proper install?
    By svs128 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2011, 10:56 AM
  3. water test values - what do you think?
    By croghanite in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-03-2011, 07:20 AM
  4. Proper install of power lead cable for suntouch mat
    By bobcatm in forum Electrical Forum discussion & Blog
    Last Post: 11-04-2009, 07:07 AM
  5. Proper Vinyl Pan Install
    By mwinnick in forum Shower & bathtub Forum & Blog
    Last Post: 09-09-2007, 07:05 PM
