Results 1 to 8 of 8
Thread: double bathroom sinks and washing machine through 2 inch drain - no vent - okay?
    DIY Junior Member leet's Avatar
    Sep 2013
    Charlotte, NC
    Question double bathroom sinks and washing machine through 2 inch drain - no vent - okay?
    Hi,
    Is it permissible and advisable to drain two bathroom lavs and a washing machine through a single 2 inch drain pipe with a run of less that 4 feet to the stack with no vent? The stack in my images also has a bathtub drain and toilet tied to it - all of this on the ground floor with no other drains or vents on this stack. I have provided two images - a photo "current" and the other image is a mock-up of my plan. I intend to move the washer drain over (laundry room is behind this wall) and add two bathroom sinks in place of a single sink.
Size:  55.9 KBName:  move laundry drain - add 2 sinks to same drain.jpg
    Thanks for your help,
    Lee
    The washer needs a vent, the lav needs a vent and the other lav needs a vent.
    Those three vents can tie together at 42" above the floor.
    You need a wye fitting or combo with waste going from vertical to horizontal. A Santee is not allowed in that position.
    A washer does a good job of siphoning traps.
    That's why they are "never" allowed in a wet vent system.
    Sep 2013
    Charlotte, NC
    Okay, thanks Terry - working on plan "B"
    Sep 2013
    Charlotte, NC
    I created a new plan with a vent for the washing machine and a shared vent for the 2 sinks - using 2" pipe for all drains and vents. Do I need the washer vent in this setup? Can I share one vent with 2 sinks? Please refer to my mock-up below and let me know what you think.
    Thanks again, Lee
    Name:  mbath with vents.jpg
    It's getting late on Friday.
    The last drawing shows s-traps on the lavs.
    The vent comes off the "top" of the trap arm, not below it.
    Here is a nice link to Bert Polk's plumbing tips
    Sep 2013
    Charlotte, NC
    First, the link you shared was very helpful - thanks!
    Would you mind reviewing the diagram I created in response to your feedback? It is intended to show the flow of the drains and vents but not the fitting details. All pipes are pvc: 3" stack, 2" drains, 1.5" vents, and 1.25" sink drain traps. I would have set up both lavs like the one on the right but there is no room in the wall to cross a drain and a vent.
    Thanks again for your help,
    Lee
    Name:  mbath with vents on sketchup.jpg
    This drawing does not work
    The revent is at 42" or higher off the floor.
    The washer standpipe is at least 18" long.
    I typically rough the lavs at 20" from the floor with a 32" counter.
    The washer box works well at 48" to the top of the box. It can be lower than that, but the standpipe must be 18" at the min. I buy the washer shutoffs with hammer arrestors.
    Sep 2013
    Charlotte, NC
    genius! thanks so much for your help! Lee
  1. Washing Machine drain-vent delima
    By carltie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-29-2013, 06:45 AM
  2. Washing machine/sink drain and vent
    By garrettgjp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2013, 08:38 AM
  3. Smelly sinks & washing machine
    By staci2310 in forum Drain Cleaning
    Last Post: 05-04-2011, 09:12 AM
  4. Help with Washing Machine trap/drain/vent
    By schomeowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2008, 09:29 PM
  5. Washing Machine Drain- vent needed?
    By jdkimes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2006, 03:05 PM
