Thread: Electrical disconnect inside cistern
    DIY Junior Member Tom in PA's Avatar
    Sep 2013
    Central PA
    Default Electrical disconnect inside cistern
    Hi,
    I am in the process of replacing a 2 wire 220v 1/2 hp Flint & Walling pump inside a 500 gal or so underground cistern.
    The cable from the house comes into the cistern above the water level and is connected directly to the pump wires with heat shrink butt splices.
    What I'd like to do on the new pump is have some way of quickly disconnecting the wiring inside the cistern in case I ever need to test the pump's internal wiring in the future.
    I know I can test from the pressure switch in my basement, but the wire to the cistern is 700 feet or so, and I'd like to be able to isolate any electrical problem to either the underground wire or the pump.
    Is there any product out there, or any suggestions about how to do this? I could keep the connection up out of the water and maybe secure it to the bottom of the lid, but of course it would be very damp inside the cistern.
    Any ideas would be appreciated.
    Thanks.
    Mar 2011
    Houston, TX
    You can use a GFCI and it will tell you when a problem exist.
    I think adding a disconnect that could be under water is a bad Idea.
    Why not put it topside ?
    Good Luck.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Bad idea, the moisture in the cistern will corrode the receptacle, you're much better off using heat shrink splice kits.
    Sep 2013
    Central PA
    Hi Don,
    I'd like to put it outside the cistern, but not really practical since it is along a creek. It doesn't flood, and the cistern never fills above the outlet pipe, but the concern is someone walking by getting into it. Rarely get anyone walking by there, but anything above ground would be too tempting I think.
    Craig, I realized a standard receptacle would be a bad idea; just thought maybe it was a common enough need someone might have some sort of moisture proof disconnect.
    Thanks to both of you.
  1. Install new line to cistern wall, worried about loose dirt flow back into cistern
    By abeljda in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-15-2010, 04:55 PM
  2. New Disconnect Box
    By Phillbo in forum HVAC Heating & Cooling
    Last Post: 07-16-2009, 04:07 PM
  3. Electrical Engineer allowed to do Electrical work?
    By willijimon in forum Electrical Forum discussion & Blog
    Last Post: 03-05-2009, 05:08 PM
  4. Finding Hot disconnect
    By colbymom in forum Electrical Forum discussion & Blog
    Last Post: 07-08-2008, 06:35 AM
  5. flourescent disconnect
    By mattbee24 in forum Electrical Forum discussion & Blog
    Last Post: 02-06-2008, 05:54 PM
