Thread: Well pump for sprinkler system
    DIY Junior Member PastryChef1990's Avatar
    Sep 2013
    Floirad
    Default Well pump for sprinkler system
    Does anyone know where you can purchase this piece and what it is called. It's round, has two terminals, when you take the cover off it was in the end, looks like a very large battery, seen ones online but they all have double terminals, not the single.
    Number and name Philips 111A271-1 110 VAC 60 Hz
    Jan 2008
    Virginia Beach, VA
    It's a Capacitor. Try Grainger, they should be able to match you up.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Moderator valveman's Avatar
    Mar 2006
    That is a “starting capacitor” to be a little more exact. After you get a new one and hopefully get the water back to running, you need to figure out what causes starting capacitors to go out. Start cap going bad is one of the first signs of excessive cycling on and off. You should try to solve your cycling problem because the next thing to go is the motor itself.
  1. Replacing a Goulds J10S 1 hp pump for home sprinkler system
    By drainfly in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-07-2010, 07:21 PM
  2. Replacing a Goulds J10S 1 hp pump for home sprinkler system
    By drainfly in forum Irrigation / Sprinkler Forum
    Last Post: 07-06-2010, 07:19 AM
  3. HELP! sprinkler system pump and ??????
    By floridasun in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-30-2009, 06:37 PM
  4. Going through check valves fast on sprinkler pump system
    By rgbutler in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-25-2006, 07:46 AM
  5. Suspected Pressure Tank Problem on Sprinkler Pump System
    By zestyfrog7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-22-2005, 07:21 AM
