Results 1 to 12 of 12
Thread: Repairing/replacing leaky copper DWV pipe
    Default Repairing/replacing leaky copper DWV pipe Final repairs made
    Howdy folks, while doing my routine plumbing check I found a leak at the area where everything drains out of the home. The home was built in '68 and is unfortunately all copper. While it has made small repairs easy, this one has me scratching my head. My thinking is to replace this area with PVC. I don't know whether to tackle it on my own or call a good plumber. Here is a pic of the area. At this point, the leak is small at maybe 4-5oz a day, but she could go at any time! Already a quick patch job in another spot so that is why I am thinking of gutting and replacing.
    Any ideas?
    Steve
    "Joints" do not start leaking, unless the pipe inside is eroded away, so a "repair" is not likely. The good news is that it will NOT "give at any time". It will just get worse a little bit at a time.
    Nov 2010
    Maine
    The bad news is that fixing it properly is gonna cost a bunch of money.
    So, next question. Is that side inlet elbow, installed in that position code or not ?
    Thanks for the opinions. Have no clue if the elbow is code? I have a plumber coming next week as he is swamped so I may do another patch job until then.
    When you say "bunch of money", what ballpark you reckon?
    Nov 2010
    Maine
    A major league one.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Is it me, or does that clean out looked braized?
    It's all open and easy to get at. I don't see that as a big problem. They make mission copper to plastic couplings if the plumber wants to go that route, and if so, he can massage the layout a bit.
    Had an independent plumber stop by for a look. On the plus side he said there was enough copper and space for a "not too bad" of a job and on the negative side he said it would still likely be in the $600-$700 neighborhood. Said he needed to take it back all the way to the cast iron outlet which requires cutting & drilling out the lead seal. He would also use a different configuration for the new plumbing. My Wife was expecting more like $1200 so maybe this isn't bad?
    I was going to cut & replace myself, but that last piece of vertical copper before the cast iron is paper thin and can be pushed in with a tiny bit of effort. I think I'll pay the pro this time..
    Yakima WA
    It's a wise DIY who know when his level of ability has been topped!
    Got a 2nd quote today and the plumber wants to do the same style repair, but at 3 hours and $300. Both come recommended so I'm not sure why I'd want to pay $600+ for the first plumber.
    Had the plumber out today. I guess all is well as I am no expert. Here is the before & after.
    He did a nice job with the glue.
    I've never used a 90 el with side outlet like that. So it looks interesting.
    I'm used to using wyes and santees.
    I like the shielded couplings on it. I ran across an old picture that a homeowner had posted that showed the old all rubber coupling, and then the fix afterwards with the shielded couplings like you have.
  1. replacing old pipe.....need help picking out what to use....CPVC, PEX, Copper???
    By firedogut in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2010, 05:04 PM
  2. Tricky Replacement of Leaky Copper Pipe- Need Suggestions!
    By syd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2010, 06:35 AM
  3. Replacing / repairing PRV
    By shluffer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2010, 07:32 AM
  4. Replacing galvanized water pipe with copper?
    By Irrigated in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2007, 07:47 AM
  5. replacing flange on copper pipe
    By Richard S in forum Toilet Forum discussions
    Last Post: 02-04-2005, 12:00 PM
