Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Irrigation system on a well pump
  1. #16
    DIY Member mihomeowner's Avatar
    May 2013
    Michigan
    Quote Originally Posted by Wet_Boots View Post
    If you have a Square-D pressure switch, the instructions might be on the cover. Since you say the cycling is about two minutes between starts, you probably aren't so far from steady operation.
    On a sprinkler system of rotor heads, an installer wouldn't spend too much effort tweaking a pressure switch beyond making 30/50 into 40/60 - the installer has different sized sprinkler nozzles to exchange with the installed ones, in order to get a flow match with the pump.
    I'll take a look. The first thing I need to do is switch out the pressure gauge in my system, it's 10 years old and doesn't work very smoothly any more. But I am pretty sure that is an easy fix.
    Great info. After I fix the gauge I am going to try to move it to 40-60psi. Isn't this what most homes are at? Will this make my well pump cycle more during showers and general home water usage? Obviously showers are going to be a little nicer too
    Thanks for help
  2. #17
    Feb 2011
    NW Ontario, Canada
    A higher pressure will work towards overcoming some line loss (resistance) and increase the GPM. The higher pressure will also reduce the drawdown on the tank. Lastly, depending on where on the pump curve you are, the higher pressure may reduce the GPM output of the pump. So, as you can see, without the details filled in, the difference may or may not be negligible.
    A CSV would not care about the above details and give you consistently high pressure and stop most of the cycling.
  3. #18
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Quote Originally Posted by mihomeowner View Post
    Very wise move.
  1. Iron filtration system for irrigation system
    By 311hemi in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-11-2013, 12:04 PM
  2. Designing a single well and pump system to supply both irrigation and treated water
    By Mikey in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-02-2013, 09:52 AM
  3. PRV for irrigation system?
    By snakes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-11-2013, 08:02 AM
  4. Shallow Well Pump - Constant Short Cycling with Irrigation System
    By Gheuett in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-22-2010, 05:43 PM
  5. well and irrigation system gone bad, need help!
    By Tedz241 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-10-2006, 11:16 AM
