Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Culligan Super S is "ticking"
    DIY Junior Member efbman's Avatar
    Sep 2013
    Default Culligan Super S is "ticking"
    My Culligan Super S iron filter has started ticking like a clock, only a little bit faster. It's fairly load as you can hear it when your in the basement within 5 yards of it. Other than that is seems ok since it started about 3 weeks ago. Any ideas?
    Nov 2010
    Maine
    The Taliban ?
    Sep 2013
    lol. funny.
    Nov 2010
    Maine
    Just for you Gary LOL
    ITS THE TIMER LOL
    Sep 2013
    Would that be happening if there was no water flowing? The sound happens 24/7.
    Feb 2011
    NW Ontario, Canada
    Does it have an electronic clock or a motor? Mine (other brand) has a motor and it has been ticking for around 10 years.
    Dec 2009
    Alaska
    Most likely it is of the dial clock or the pre digital time and the motor for the timer assembly is ticking. Like the Fleck timer motors that are much like it they can tick like that from the start or start later in life.
    They can tick for some time or saying that it is about time to say good night for the timer and check out.
    Does it look some thing like this?
    Name:  Culligan Timer Assembly B.jpg
    Sep 2013
    Akpsdvan, that is exactly what it looks like. I now believe it is the round motor(?) on the right that shows blue through the openings. Is that the "timer motor"?
    Dec 2009
    Alaska
    That is the timer motor.
    Some go for some time ticking before the die, others tick and a very short time later they die, it is any ones guess as the time left.
    Sep 2013
    Any idea where I can order one?
    Dec 2009
    Alaska
    Of the few culligan dealers that are on line I have not seen many if any that sell parts.
    Might be able to buy one from a local dealer , but that might be a challenge in that culligan has moved to the digital control boards so the style like yours may not be available any more.
    I have seen different culligan items for sale on that bidding site that has been around for some time , starts with E... some new parts and then some old controls or used timer assemblies like the one in the photo that I posted.
    Drop a pm if you would like.
    I'm not a culligan man but if its a metered valve, there's a turbine in there that counts gallons so it may be something got in the volute and the turbine is wacking it.
    I guess you thought a Culligan meter is different somehow from any other meter used on other brands of control valves. LOL And then there is that part you forgot about, the noise happening when there is no water being used... A troubleshooter yer not.
    Nov 2010
    Maine
    Did his 1st post say anything about ticking when water is not being used? Ahhh no.
    Do other metered valves occasionally pick up a ticking sound ahhhh yes.
    Unlike you, I like to keep an open mind when troubleshooting
    Did I Not say that I am not the culligan man? I did. I know nothing about culligan valves. Seen a few, never worked on any and since there are a few manufacturers out there that make some very different valves like Kinetico, well nice try skippy
    You keep throwing the bait but nobody's biting LOL. Try PLB.com there's always someone over there that will dance with you LOL
    Jan 2012
    California
    Actually, anybody who has field experience would know that a little ticking noise is not that uncommon from a wearing meter turbine bearing/bushing or small piece of debris in the meter. Most electronic valves do not make any noise unless they are running water. Had the OP posted a picture of the unit, we would have went to the electromechanical time-clock portion of the system first.
    Keep on trolling!
    Nov 2010
    Maine
    Hey, like I said, I read the first post, no mention of water running or valve type. I went with what I have encountered the most often in the last 40 years of servicing filtration. Troubleshooting is a process of procedural deduction and most competent technicians always start with the obvious or most common and work backwards from there. So I didn't hit he nail on the head the first time given the information I had to go on. Had I been following the thread, which I wasn't, after the OP said it ticks all the time I would have then moved on to the mechanical timer. Note that my detractor never nailed the problem either and only bothered to throw his two cents worth of useless comments in in an attempt to illicit a negative response from me in the way of a personal insult. Hey, not gonna happen. No point. We all know who he is and what he is all about by now.
    Fortunately most of the professionals like Akspdvan and others that post here are just that and willing to help rather than waste everyone's time trying to start an argument, or tossing insults. I guess at least one member here must br anti DIY LOL.
  1. Culligan Super S with yellow/brown water
    By mightymoose in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-24-2013, 08:04 PM
  2. Help with Culligan Gold Series Metered 9" WS float
    By coriolis2k in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-14-2013, 06:18 PM
  3. Culligan Super S not pulling bleach
    By jreed in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-19-2013, 04:32 PM
  4. Copper Pipes "Ticking" Mystery
    By jjtrindc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2012, 07:53 AM
  5. Sewer Pipe "ticking"
    By Zundey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2005, 03:17 PM
