Results 1 to 9 of 9
Thread: Occasional leak from drain of fiberglass shower unit.
    DIY Junior Member Jimmy leakbegone's Avatar
    Sep 2013
    Pennsylvania
    Default Occasional leak from drain of fiberglass shower unit.
    I have a fiberglass shower unit on 2nd floor of my home. Shower only, not a tub. Whenever I am away from home for about 4 days or more, when I take the first few showers after arriving home, it leaks profusely into kitchen below. My retired plumber friend takes drain apart and re- puttys it and it is fine, until the next trip away from home. This has occurred about six times so the putty fix is not the answer. What can we do for permanent fix? I have a drop ceiling below the shower so we can get to the underneath if necessary.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    How old is this shower?
    You may have a problem with the drain hole, something that fresh putty or a new drain set can't fix. Have your plumber look at the round hole next time he comes to put new putty.
    Most "drain holes" are NOT installed so you can take them apart and install "new putty", so I am not sure how yours is installed. Use a silicone caulk instead of putty.
    I'm also using Silicone on shower drains. I've removed way too many that were installed with putty.
    If the shower pan flexes when you step on it, that's the first issue. On fiberglass (and actually most plastic materials), flex will eventually cause spiderweb type cracks, and it might not be the drain entirely at all. But, movement of the pan to a drain pipe that may be supported will also affect the longevity of any seal. Silicon is more like a glue and is flexible, so it can handle some of that movement. The better, long term answer when first installed, would be to provide support underneath the pan so it is solid and can't move. It could move because the floor isn't flat or just because of design, should have had something installed to fill in the gaps to make it more rigid.
    It's really difficult to add support underneath a shower pan after it's already installed.
    Sep 2013
    Pennsylvania
    The unit is about 16 years old. When not in use for a few days, it must dry out and contract, causing cracks. Will try a silicone based sealant and see if that helps. I do notice some flex when taking shower. May need to remove and re-install?
    Sep 2013
    Pennsylvania
    Should I think about removing unit and reinstalling with more support? If I do that, would it be wise to buy new unit or use same one?
    Sep 2013
    Pennsylvania
    Thanks to all those who replied.
    Inspect it carefully. If you cannot see any cracks, it might be safe to reuse, but at 16-years, I think you'd be better off with a new one.
  1. Need to replace one-piece fiberglass shower/tub unit
    By suceress in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2013, 11:02 AM
  2. Best way to reattach glass door unit to fiberglass shower wall?
    By nightowl in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2009, 06:04 PM
  3. blistering fiberglass tub unit
    By Laina in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2007, 05:17 AM
  4. Installing drain on fiberglass shower unit
    By chiguy in forum Shower & bathtub Forum & Blog
    Last Post: 04-06-2006, 08:09 AM
  5. sweating near fiberglass tub/shower unit
    By newbie in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2005, 05:47 AM
