Thread: Extend well casing - weld or Dresser coupling ?
    DIY Junior Member Astrowood's Avatar
    Sep 2013
    New Brunswick
    Default Extend well casing - weld or Dresser coupling ?
    My well has not been touched in 32 years. I have used, and repaired jet pumps 3 times in the past - now is the time to go submersible. The top of the well was buried 3 ft deep (not deeper than the frost line, and yet has never froze - I live in Canada) and I have plenty of surface water as the pit has filled with a foot of water each day as I prepare the hole for the new casing. I have called a local welder with lots of well casing experience, and I have also priced a Dresser coupling which has a 10" reach (5"on each pipe, epoxy coated, stainless bolts).
    The cost of welding is within $10 dollars of the price of the coupling. Using the coupling has a real time advantage for me (scheduling of welder), and solves a couple of other minor problems. The coupling is the exact match for the well pipe and extension.
    Am I nuts for considering a coupling over welding ? As I mentioned, lots of surface water, and well contamination is a concern. The well is in the backyard and in no danger of being hit by anything.
    Thoughts ??
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I have used Dresser couplings and I have welded casing extensions, never had a problem with either one.
    Nov 2010
    Maine
    Personally, I think a dresser coupling is fine but the code says otherwize.
    Jan 2008
    Virginia Beach, VA
    I would approve a properly installed dresser coupling however it depends on what the state approves.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Dresser coupling with galvanized pipe
    By shnaig in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2012, 03:14 PM
  2. PC to ABS: Fernco or solvent weld?
    By dgold in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2011, 04:13 PM
  3. Dresser coupling on hot water heater
    By KinLI in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-14-2008, 08:37 PM
  4. Solvent weld tub drains
    By tomcat22 in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2008, 07:18 AM
  5. Solvent Weld vs No Caulk
    By Blaze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2007, 06:06 AM
