Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
Thread: Vandalized well on fixer upper.
  1. #31
    Moderator valveman's Avatar
    Mar 2006
    From those ohm readings I am guessing a 3/4 HP.
    7 amps is 3/4 HP, 9 amps is a 1 HP. But it won't hurt to have a 1 HP box on the 3/4 HP pump. If the motor is that old, it may not have a built in overload. So you may want to add a 3/4 HP overload to your new box.
  2. #32
    DIY Junior Member Billyfixit's Avatar
    Sep 2013
    florida
    The motor/pump was installed in 98. The old conrol box was a redhat and the one I replaced it with was a redhat and virtually identacle. Neither box has a overload. I assumed that the motor has an overload and you said you belived so as well on page 2 of this thread. The breaker for it is 25A I believe. Do you think I should add an overload? As I said, it originally didn't have one in the original box.
  3. #33
    Mar 2006
    I can't remember when it happened, but I am pretty sure motors in 98 had built in overloads. But if there is one in the control box, there usually isn't one in the motor.
  1. Vandalized & Beaten AC Compressor - Has anyone seen this before?
    By lukekb in forum HVAC Heating & Cooling
    Last Post: 12-13-2009, 11:42 AM
  2. WH on apt. bldg upper floor
    By philbob57 in forum Water Heater Forum, Tanks
    Last Post: 07-31-2009, 04:54 PM
  3. Rough piping a new upper bath
    By mar-todd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2009, 10:41 AM
  4. Help with Upper water heater element.
    By tlong_66 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2008, 08:56 PM
  5. Upper Thermostat wiring
    By erikthewarm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2005, 07:21 PM
