Results 16 to 30 of 33
Thread: Vandalized well on fixer upper.
  1. #16
    Mar 2011
    Houston, TX
    I still think it is a 1.5 HP. I guess you could put a new 1.5 HP box on there and try it. Then it would run so you could check the amp draw to make sure what size of pump it is.
    I think that this is correct.
    The current measurement would be the best check. That Box may work OK, to test the motor, even if it looks in bad shape.
    That Tyco Relay would be correct for a 1.5 HP motor. (Current rating and Coil Drop out Voltage)
    Any larger motor would not be good design practice, using that relay.
  2. #17
    DIY Junior Member Billyfixit's Avatar
    Sep 2013
    florida
    I guess I could use the box but not the relay. It was full of water. The cover was taken off of it years ago when it was vandalized.
    Also, I don't want to buy a control box if its the wrong size. I won't be able to take it back and they're not cheap. I'll check ohm readings between the motor wires and see if that will help.
    edit: Being that its a crc box with a start and run cap, is their a difference in pressure switches for crc vs. non crc? Can you link me to one that would work for a 1.5 hp? (saying that thats what it is)
  3. #18
    Moderator valveman's Avatar
    Mar 2006
    For 2HP and smaller all you need is the standard Square D FSG2. It is like 15 bucks.
  4. #19
    Mar 2011
    Houston, TX
    I would use a Square D, and not the other off brands that HD sells.
    A standard 2 pole pressure switch will work, but some are junk.
    Good Luck.
  5. #20
    Sep 2013
    florida
    So I took ohms messurement on the pump. It took quite awhile for the meter to settle down on all the readings. Is that normal? Anyway, here they are.
    red/yellow 13.6
    red/black 15.8
    black/yellow 5.
    I checked them all to ground and there was no reading.
    So what do you guys think?
    edit: also, in my first post on here you can see a bit of the bladder tank. (at least I think it is)
    Their is no shrader valve on it. It has a couple of plastic pieces on top of it but they don't appear to come off. Is it like precharged at the factory or something?
  6. #21
    Mar 2006
    From those ohm readings I am guessing a 3/4 HP. But if you purchase a 3/4 control box and it pulls more than 7 amps, your screwed. It is very rare for a cap run control box to be on anything smaller than a 1.5 HP. 1.5 HP is going to pull 11.9 amps.
    There is a Schrader valve on the top of that tank somewhere. One of those plastic things comes off.
  7. #22
    Mar 2011
    Houston, TX
    Quote Originally Posted by Billyfixit View Post
    red/yellow 13.6
    red/black 15.8
    black/yellow 5.
    That is close to what a 1/2 or 3/4 HP would read.
    Hard to tell for sure because your readings do not add up.
    Red/Black should be 18.6 ohms if your other two readings are correct.
    Good Luck
  8. #23
    Mar 2011
    Houston, TX
    I agree, Sounds a bit strange.
  9. #24
    Sep 2013
    florida
    Well I guess I could get the start cap tested. I tested it with a digital meter and it just read OL. Likely need an anolog to see if its OK although I know thats not going to tell me the micro farad rating but it would tell me if it can be tested. Took it to radio shack and they laughed. They can only test little mini caps.
    What would happen if I was oversized on the box? i.e. 3/4 hp pump with a 1 hp box. Would the larger caps eventually destroy the motor?
  10. #25
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Got news for you Don, new Square D pressure switches are just as bad as any of the others and they cost more to boot.
    I doubt an over sized box will hurt the motor, I have used them when I didn't have the right box on the truck with no problems.
  11. #26
    Mar 2006
    Quote Originally Posted by craigpump View Post
    Yeah the little plastic part that holds the points is no where near as good as the old fiber board was on those Square D switches.
    Yeah since overloads are in the motor there should not be any problem. I've used larger boxes many times as well with no problems.
  12. #27
    Mar 2011
    Houston, TX
    That is funny that they say they can not test that cap. Workers at Radio Shack only know Cell Phones now a days.
    The only difference in the cap size is the voltage rating and most cap testers will check up to 1000uF.
    http://www.radioshack.com/product/in...6&locale=en_US
    A 1 HP box should work fine but will cost a bit more.
    Good Luck.
  13. #28
    Sep 2013
    florida
    Thanks guys.. I'm going to go with a 1 hp crc control box and let the dice roll. Will post results or questions.
    Thanks again, really appreciate it.
  14. #29
    Sep 2013
    florida
    Hey guys.. just wanted to say thanks. I went with a 1 hp redhat controller and it worked fine. I did an amp draw and was looking at 6.1 amps per leg. Everything works just fine. It spewed out some muddy water for awhile but then was crystal clear. It holds pressure very well too. Talking to the neighbor, his is drilled 240 ft and its in a aquafir so the water is very good. I assume mine is about the same depth etc..
    Only prob I have is half the cpvc under the mobile home is cracked to bits. Apparently it was full of water and froze at some time and most of it all split open. I replaced about 2/3rds of it so far and then its on to the sinks and toilets as they all drip or leak. lol..
    Anyway, just wanted to say thanks again. I really appreciate everyone that helped me out. I really didn't know much of anything about deep wells or two cap control boxes and you guys helped me get it up and running..
    cheers!
  15. #30
    Mar 2011
    Houston, TX
    Good work Billy.
    Thanks for the update.
    Enjoy.
  1. Vandalized & Beaten AC Compressor - Has anyone seen this before?
    By lukekb in forum HVAC Heating & Cooling
    Last Post: 12-13-2009, 11:42 AM
  2. WH on apt. bldg upper floor
    By philbob57 in forum Water Heater Forum, Tanks
    Last Post: 07-31-2009, 04:54 PM
  3. Rough piping a new upper bath
    By mar-todd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2009, 10:41 AM
  4. Help with Upper water heater element.
    By tlong_66 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2008, 08:56 PM
  5. Upper Thermostat wiring
    By erikthewarm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2005, 07:21 PM
