Results 1 to 9 of 9
Thread: Washing Machine standpipe height?
    DIY Junior Member katespade's Avatar
    Sep 2013
    San Jose
    Default Washing Machine standpipe height?
    GE high efficiency washing machine drum broke. Replacing with LG high efficiency 5.1 cu. ft. model. The current setup is such that the p-trap is 2 feet above ground and the standpipe is 1.5 inches pipe that is 21 inches in length. Would that work for the LG 5.1 cu. ft model ? I had absolutely no problems with the previous washing machine as far as draining was concerned.
    Tks.
    That puts the top of the standpipe at 45" from the floor
    edit by Terry
    No way to tell you. It depends on how fast the washer pumps the water out. If the 1 1/2" riser is adequate it will drain, if not it will overflow.
    Like mentioned above, is the pipe is clear and fast running, it may work.
    In the last fifty years or so, they moved to a 2" trap and line. However, there are still plenty out there done with 1.5" that are still in use.
    I sometimes make the standpipe 2" if its open and I can make the change easily.
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    If it is open, I have made the standpipe 3" or 4" (strap it to the wall).
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Ideally, the standup pipe should be about 42"-48" tall.
    Nov 2009
    Victor, MT
    The UPC states the standpipe must be between 18" & 30" tall. Most plumbers go for 30".
    Aug 2013
    California
    A standard washer is about 36" tall. The panel is another 6" or so. Together we have, where is my calculator oh here it is, about 42". So around here, the stand pipes are 42" to 48" tall.
    Newer washers are on pedestals and are even taller than 42".
    Nov 2009
    Victor, MT
    The standpipe is 18" t0 30" tall (usually 30"). The trap is roughed in at 6" to 18" above the floor (commonly 12"). (UPC 804.1). 30" + 12" = 42". The trap can be roughed in at up to 18", which gives 48" total height.
    Aug 2013
    California
    Quote Originally Posted by asktom View Post
    ...Now it's clear...
  1. Washing Machine Standpipe...Remedy An S-Trap
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2012, 11:50 AM
  2. Where to add washing machine standpipe to stack
    By jerry_johnson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-21-2012, 07:03 AM
  3. Washing machine standpipe leaking
    By Sel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-03-2011, 07:52 AM
  4. washing machine standpipe???
    By Master Brian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2009, 08:16 AM
  5. Unused Washing Machine Standpipe
    By jdoll42 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2008, 07:37 PM
