Results 1 to 13 of 13
Thread: New TOTO Connelly and ECO Drake and Ultramax II 1G
    Apr 2012
    New York, NY
    Default New TOTO Connelly and ECO Drake and Ultramax II 1G
    Well, it looks like Toto is coming out with (but has not yet shipped) three new designs. (As with the original 1G, the stuff gets announced months before it is actually available.)
    CST494CEMFG
    A brand-new "Connelly" toilet, which will be "Dual-Max Cyclone" (.9 and 1.28) like the Maris floor-mount.. http://www.totousa.com/ProductDetail...productid=1282 The Press Release says "skirted bowl" but it doesn't look like a typical Toto skirted (those look like closet bolts there), so who knows; also, the trapway looks kinda short, but I guess we shall see... http://www.totousa.com/Press/PressRe...ellySuite.aspx
    • Dual-Max® Cyclone® fl ushing system, high efficiency (1.28GPF/4.8LPF & 0.9GPF/3.4LPF)
    • Dual flush function
    • Elongated bowl
    • Universal Height
    • Close coupled bowl and tank set, less toilet seat
    • SanaGloss® ceramic glaze minimizes debris, mold and bacteria from sticking to porous, ceramic surfaces
    • Chrome trip-lever
    • 12" Rough-in
    A hard-to-get-used-to new tank for the original Drake 1.28 version. http://www.totousa.com/Press/PressRe...nsitional.aspx
    Upon further review, it appears that Drakes with this new tank are available to be ordered, if not heavily in stock at many places. The MSRP is about $30 more than the unit with the old tank. The new model numbers are the same as the old model numbers, with the exception of an "N" added to the model. So, whereas the elongated original Drake with the old tank is CST744E in the 1.28, the elongated original Drake with the new tank will be CST744EN. And so on. They are also making a version of the new tank with a right-hand trip lever, but it's unclear whether they will be making the bolt-down lid, insulated tank, etc. SPEC SHEET FOR CST744EN Whereas the tank was model number ST743 for both the CST744E (elongated) and CST743E (round) -- i.e. there was no ST744E tank -- the new tank has been given model number ST744E for use on both the round and the elongated bowls.
    One other oddity about the new tank is that the spec sheet now claims that the space between tank and wall on the Round Drake is between 5/16" and 1" and on the Elongated Drake is between 1/2" and 1-1/8". That's a huge variance, well beyond any kiln-error numbers. As you know, the CST743E tank regularly left 1" to 1-1/8" between tank and wall, allowing this toilet to be squeezed in on irregular rough-ins. I don't know what the point of that spec is, except perhaps to suggest that if you back the most-protruding portion of the base against the wall, there will be 5/16" behind the tank, and otherwise a full inch? It's really quite unclear.
    An Ultramax II that uses only 1 gallon per flush (like the Drake II 1G). http://www.totousa.com/Press/PressRe...ltraMax1G.aspx Note that Toto feels compelled in its press release to slam the pressure-assist technology, implying that it is dangerous. A little over-the-top stuff from the marketing department, I think. http://www.totousa.com/ProductDetail...ProductID=1285
    Well, while an infrequent thing, I've never heard of a gravity flush toilet flinging porcelain shrapnel at anyone, but it apparently has with a pressure-assisted toilet. Agree, though, that it is rare, and solved if people actually heeded the recall (although I wouldn't be too confident in the installation rate of the retrofit kit).
    DIY Senior Member lordmoosh's Avatar
    Aug 2007
    USA
    How well do the 1 GPF toilets like the Drake II 1GPF work? Any reviews?
    The Drake II 1G, CST454CUFG at 1.0 gallons is rated at 800 grams.
    That's pretty darn good.
    Apr 2012
    New York, NY
    Quote Originally Posted by lordmoosh View Post
    There aren't a lot of reviews of the 1G around the Web, but the ones that are there are 100-percent-universally-fabulous. Comments like, "The best ultra-low-flow made. Never needs a plunger." "Can't believe it flushes this well on one gallon of water." Stuff like that. Of course, you have to consider that folks who will go out of their way to buy the 1G version are going to be predisposed to accept the limitations of a one-gallon flush. Unlike the many reviews we see here where people mention that they usually hold down the handle of their toilet for a "full flush". (Sigh.) I'm fairly confident that if you forced every toilet buyer to buy the 1G, you'd get complaints about bowl rinse or questions about how to make it do a "full flush" (i.e. 3 gallons). But for people who want to save water, I think the reviews suggest that it's a winner.
    And, as Terry points out, 800MAP is impressive for a 1.6gpf toilet, much less a 1.0gpf.
    Aug 2007
    USA
    Quote Originally Posted by wjcandee View Post
    I will keep an eye on the Ultramax II 1GPF when I finish renovating my master bathroom. We like the 1 piece Totos the best.
    Apr 2012
    New York, NY
    Cool. The only danger is that the 1G system, as installed in the Drake II, replaces the simple flapper flush valve and standard trip lever. Instead, they have a gear-thingy on the trip lever that's connected to a wrapped wire that's attached to a flush-tower assembly. This apparently is to more-precisely-control the flush. It may be that the hole in the porcelain is the standard size that's used in the Drake II (although the 1G tank itself is a different shape from the standard Drake II), and thus you MIGHT be able to use the Korky 3" flush valve replacement kit and a new standard trip lever on it if you hated it, but I'm not sure. It's just less of a backup plan than one currently has available with the 1.28 system, which can be easily converted to flow a little more water per flush if necessary. We haven't found the need to do so, so I guess this is conjecture, but it makes the decision a no-brainer if there's a way to reverse it if it sucks. That said, as I say, the reviews have all been very positive, including one that I think someone posted on here with pictures. Okay, found it -- start looking at post #12 for photos and some comments by a guy who bought and installed one (you can see the interior guts in his photos): http://www.terrylove.com/forums/show...light=drake+II
    Apr 2012
    New York, NY
    UPDATE: It looks like the Cotton White version of the new-tank Eco Drake, CST744EN and CST743EN, is now in stock at HM Wallace, a major wholesale master distributor, which suggests that it is now available at a number of wholesalers' warehouses.
    DIY Junior Member mchristo's Avatar
    Nov 2009
    New Hampshire
    Default Toto Connelly reviews?
    does anyone have any reviews on the Connelly?
    I'm ordering 6 toilets and considering these, but can't find much info on them. It looks like its only been out for about 1 year.
    My other option is a Drake II.
    I have a Soiree and love it, but don't like the plastic rough in and the dripping noise that you get with it.
    Apr 2012
    New York, NY
    The Drake II rocks. Simple innards. Very popular.
    The Connelly is available, but doesn't seem to be in wide distribution. It has the dual-flush, and thus a more complicated flush valve; not just a flapper.
    DIY Member Wallijonn's Avatar
    Jun 2013
    Arizona
    ... The new model numbers are the same as the old model numbers, with the exception of an "N" added to the model. ... Whereas the tank was model number ST743 for both the CST744E (elongated) and CST743E (round) -- i.e. there was no ST744E tank -- the new tank has been given model number ST744E for use on both the round and the elongated bowls.
    I think that the new tank is hideous. I just hope that they will never put them on the Drake toilet. (Well, they are if the info above is correct). If they're going to do that then I think I had better order a CST743R or CST743SR now. My fear is that since so few order a right hand tank that it would be quicker to make the new 'N' tank with the right hand flush since it's a special order.
    Jun 2013
    Arizona
    Why isn't there a Drake Round with Sanagloss? Not that it would matter - not if it came with that new bowl.
    Quote Originally Posted by Wallijonn View Post
    Most rounds bowls are bought because they sell for less. You won't see many upgrade features on round bowls.
    TOTO does make a Sanagloss round bowl in the Promenade.
  1. Toto drake ii or ultramax ii?
    By jkhott in forum Toilet Forum discussions
    Last Post: 07-21-2013, 05:57 PM
  2. Toto Eco Drake and Eco Ultramax vs Drake II and Ultramax II
    By jla in forum Toilet Forum discussions
    Last Post: 08-05-2012, 08:30 AM
  3. Toto-Drake, Eco-Drake, UltraMax
    By Decisions4us in forum Toilet Forum discussions
    Last Post: 06-17-2009, 09:31 AM
  4. Toto Drake or Ultramax
    By shinerburke in forum Toilet Forum discussions
    Last Post: 01-01-2008, 09:07 AM
  5. TOTO UltraMax vs drake
    By plant59 in forum Toilet Forum discussions
    Last Post: 02-02-2007, 02:40 PM
