Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Intake piping on bottom of lake
    DIY Member bassadict69's Avatar
    Oct 2010
    Benton, La
    Default Intake piping on bottom of lake
    I am ready to permanently run the intake plumbing to an irrigation pump on our dock. How should I run this and how should I hold it down on bottom.
    I am thinking that I will come off the pump intake, down into the lake and down to the bottom then run the piping through several cinder blocks spaced one per 10ft or so until I get it out to deeper and weed free water, then put the foot valve.
    Also, is some sort of filter recommended over the foot valve?
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    If you plan a permanent fixed suction line to a pump, you might do with a check valve at the pump intake, rather than a foot valve. That approach also gives you some freedom to choose an intake strainer/screen that fits your system and sprinkler heads, in the event that they want cleaner water.
    Feb 2011
    NW Ontario, Canada
    Some folk use a sandpoint and a checkvalve instead of a footvalve.
    Mar 2011
    Houston, TX
    Quote Originally Posted by bassadict69 View Post
    I use 2" pvc about 3 foot long with 1/8 inch holes drilled every 1/2 inch. Then I have a fiber filter over that, that I can rinse easy. It will stay on the bottom when filled with water.
    That keeps fish from getting sucked up and sticking to the inlet.
    However you do it, you will have to clean some type of filter on occasion.
    Good Luck.
    Oct 2010
    Benton, La
    Thanks guys!
    Oct 2010
    Benton, La
    Rookie here! LOL! Can you explain sandpoint?
    Feb 2011
    NW Ontario, Canada
    It is a long screened casing usually hammered into the ground.
    http://lmgtfy.com/?q=sandpoint+well
    Mar 2011
    Houston, TX
    You need to make sure your area will allow a sandpoint in the lake. It will most likely be in the mud, in your area.
    Some locations do not allow taking water from a lake for irrigation. Temporary is a bit different than permanent.
    Good Luck.
    Mar 2011
    Houston, TX
    That link did not work for me.
    Oct 2010
    Benton, La
    We have to pay a yearly fee to draw the water, but it is allowed. Most homeowners on the lake pump water from the lake for their irrigation system.
    Mar 2011
    Houston, TX
    That is good.
    You have more fresh water than we do.
    How big is your pump inlet ?
    Good Luck.
    Oct 2010
    Benton, La
    intake is 2 inch
    Mar 2011
    Houston, TX
    I guess people around you would know how to do it properly.
    It will have to be done in a way to protect fish from sticking to the inlet.
    And keep boat props out of it.
    Have Fun.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I think this is what Lligetfa is talking about.
    http://www.homedepot.com/p/Brady-1-1...5-04/100172153
    •Also used for de-watering and drawing water from canals, lakes and ponds
    •Prevents sand from coming through the slots, but allows water to flow freely into screen
    Oct 2010
    Benton, La
    Confused? That gets driven into ground/bottom of lake?
  1. lake water supply setup. in Ct lake
    By tooks7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-07-2012, 12:10 PM
  2. What to do with the fresh air intake
    By jp102 in forum HVAC Heating & Cooling
    Last Post: 11-23-2011, 09:24 PM
  3. Winterize lake water intake to cottage
    By lhartl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-02-2009, 05:54 PM
  4. Fresh Air Intake
    By PistonDog in forum HVAC Heating & Cooling
    Last Post: 09-09-2009, 03:38 PM
  5. Bottom of Pump / Bottom of Well
    By GPM in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-01-2007, 05:35 AM
