Results 1 to 11 of 11
Thread: fuse gets extremely hot and lights flicker
    DIY Junior Member candy74's Avatar
    Sep 2013
    South Carolina
    Default fuse gets extremely hot and lights flicker
    My lights started going dim then get bright so I had an electrician come check, he changed a main fuse that had blown but he said it was still making a connection and that was the problem, day later the lights are still doing the same thing. I went to the fuse box and the main fuse is extremely hot. I hope someone can give me an idea as to what may be causing this. I can't pay another 350.00 for someone to come out.
    Thanks in advance
    There is to much current or poor or corroded connections.Call the electrician back before you have a fire. Any service man worth paying for should not charge full rate or much extra if the problem was not resolved from the 1st visit.You may need to change the fuse box for breakers because of the fuse boxes age and inability to repair. Now that will cost some$$$$$
    Politicians are like diapers. You need to change them often……for the same reason.
    Mar 2011
    Houston, TX
    Quote Originally Posted by candy74 View Post
    Thanks in advance
    A Fuse should not get Hot.
    If it does then there is a loose connection.
    Call him back and ask why ?
    Sep 2013
    South Carolina
    Thank you. I called he said to call the power company that it must be a loose netural on the main line. I am more than confused and very worry now.
    DIY Senior Member Murphy625's Avatar
    Jul 2013
    Michigan
    Bad connection (corrosion?) causes resistance = creates heat. I would turn off power to the box (pull meter?), clean all contact surfaces until shiny.
    Mar 2011
    Houston, TX
    If the problem is after the meter, then it is your problem, or his.
    At least the Power company will Pull your meter if your panel is not safe.
    Then you will need a inspection to get power restored.
    Good Luck.
    Sep 2013
    South Carolina
    I know this may sound crazy but what kind of questions do I need to be asking him. I told him what was happening he said that the main fuses {they are 100 amp buzz fuses} would get hot when pulling a lot of power.
    Mar 2011
    Houston, TX
    Heat means some resistance in the fuse holder or wiring in your fuse box, normally.
    You have told him enough , IF he is a Real Electrician.
    Sep 2013
    South Carolina
    Thank you so mush
    Jun 2007
    North Carolina
    Contact the licensing board in your state and I promise he will be back and fix the problem for no charge
    Sep 2013
    South Carolina
    Thank You I will do that if he refuses to come back.
  1. Lights intermittently flicker in whole house.
    By jman2012a in forum Electrical Forum discussion & Blog
    Last Post: 02-08-2013, 01:11 PM
  2. Lights flicker and things shut off randomly :(
    By GUITAR1989 in forum Electrical Forum discussion & Blog
    Last Post: 03-16-2012, 08:40 PM
  3. Well pump stutters and hesitates then shuts off and lights in the house flicker
    By joshdeeh in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-13-2011, 07:01 AM
  4. Replaced two regular lights with fluorescents = Now they flicker - HELP
    By bighunk7490 in forum Electrical Forum discussion & Blog
    Last Post: 04-26-2010, 10:04 PM
  5. Lights flicker and Voltage Drop Question
    By Pip in forum Electrical Forum discussion & Blog
    Last Post: 12-18-2008, 06:25 PM
