Results 1 to 4 of 4
Thread: Grohe - Can't see how to remove handle
    DIY Junior Member mrvf's Avatar
    Nov 2011
    NJ
    Default Grohe - Can't see how to remove handle
    Hello,
    I have a Grohe 29.238 (discontinued) wall volume control mount. I've taken the thermostatic valve apart a couple of time. But, I can't figure out how to take the handle off the volume control above it. It looks like it should slip off. There is no bolt connecting it on the outside. But, I didn't want to pry it too much in case I'm missing something. Can anyone help me with how to remove the handle so I can get to the cartridge? Attached a pic so you can see what part I mean. Thank you. MRVF
    I DOES "slip off" but it takes a lot of force to do it. If you wrap it good and then grip it with Channellock pliers it will pull off.
    Nov 2011
    NJ
    Thanks - will give that a try.
    Nov 2011
    NJ
    That did it - thanks!
  1. Grohe Bathroom Faucet - How to remove cartridge??
    By chitowngreeny in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2012, 04:37 AM
  2. How do I remove this Grohe part
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2011, 09:35 AM
  3. How to remove Grohe Sinfonia Faucet
    By atulc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2011, 04:24 PM
  4. remove cartridge from Grohe model 33619
    By rjgogo in forum Shower & bathtub Forum & Blog
    Last Post: 11-25-2009, 04:52 PM
  5. Can't remove handle hub on Moen Monticello 2 handle faucet
    By jaobrien6 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-04-2007, 06:47 AM
