Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Older Rainsoft LMB 1135
    DIY Junior Member boazcan's Avatar
    Sep 2013
    tampa
    Default Older Rainsoft LMB 1135
    Hey Guys -
    Been nosing around here, but cannot find my specific issue discussed. If there is a link that you know, please post it and will go from there. Thanks!!
    I have an older 10/2000 manufacture date that I inherited with the house that we bought a few years ago. It has been working pretty good, but recently just stopped working. I didn't see a fuse or breaker on the control panel visable. I was curious the troubleshooting steps to figure out the malfunction. It will not manually regenerate. It has always done that with no problem. Seems to be no power to the control panel/head.
    Thanks for your time and assistance!
    Bryan
    Dec 2009
    Alaska
    Photo of the unit would help, but I will go with the Fleck 5000 like valve with the non digital set up, dials and wheels on the front.
    Either the timer motor is bad or if there is a trans former it is bad or both.
    Jan 2012
    California
    Picture please. Rainsoft uses pretty standard equipment. We can usually figure out what it is with a picture.
    Nov 2010
    Maine
    If you have a multimeter check for voltage to the timer motor. If not check the transformer
    Sep 2013
    tampa
    Sorry for the delay, thanks for the feedback.
    Jan 2012
    California
    Wow, an old Intermatic timer. It is time for retirement.
    Dec 2009
    Alaska
    But the odd thing is that the date is 2000.
    I think it was one of the last of that timer but on say the 5000 valve?
    A photo from the back?
    Jan 2012
    California
    Agreed. I used that timer for many years on the old Schurz valve and the aquamatic nests. Bruner and more. I have only seen it on a few others, the piston driven aquamatic from the 80's? Please post more pictures.
    Sep 2013
    tampa
    Sep 2013
    tampa
    Dec 2009
    Alaska
    The last of that type of valve and control.
    It is time to look for a replacement rather hand trying to track down the parts for it as most likely you will not find them in any short order.
    Nov 2010
    Maine
    Maybe eeeeee**** but i doubt it.
    www.craigslist.org is a more likely place to find an old used RS softener or control valve.
    Nov 2010
    Maine
    See how easy it is to be helpful?
    Sep 2013
    tampa
    Is there a link to a replacement for this set up? I would rather replace it. Is it better to just buy an entire new set up? If so, what would you recommend? 4 person house, typical family setup. Thanks.
  1. Another question about a Rainsoft system!
    By ATKT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-07-2013, 05:36 PM
  2. Rainsoft AMB 744 CT 60HZ replacement
    By westindies in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-04-2013, 12:34 PM
  3. Rainsoft AQB Series E
    By Max1956 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-26-2013, 08:35 AM
  4. rainsoft system
    By kamr60 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2011, 06:38 PM
  5. How to remove Rainsoft
    By suem600 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-24-2009, 06:06 PM
