Thread: Dual temperature POU heater?
    DIY Junior Member boomboxnation's Avatar
    Sep 2013
    san francisco
    Question Dual temperature POU heater?
    Our tanked water heater just blew out. Considering that this one only supplied hot water for our kitchen sink, I am thinking of an under the counter electric to replace it. I was just wondering if there is a model out there that provides both 'normal' hot water as well as a dispenser for 'near boiling' water? I have tried every google search known to man, as well as combed this forum...nothing turns up. Seems like a no brainer...but I can't find it.
    Thanks in advance...
    In the trades Dana's Avatar
    Jan 2009
    Having an untempered 'near boiling' output from a water heater would be a code violation, though you could probably hack an electric tankless to deliver a temperature that high.
    The highest settings I see from water heater that's not for "Instant Hot" devices seems to be 180.
    I think you are looking at two seperate devices.
    The issue with near boiling temperatures is with any slight error, it could flash to steam and become a bomb unless specifically designed for it. The larger the water tank, the bigger the bomb potential, which is why most hot water dispensers either make it as you request, or have only a small tank.
    For water out of your tap in a home, code wants it limited to less than 120-degrees (but the tank could be hotter - code would require it to have a tempering valve on the outlet to limit it, though).
  1. Water Heater Temperature Question
    By Deltaman in forum Water Heater Forum, Tanks
    Last Post: 03-21-2010, 08:44 PM
  2. Gas Hot Water Heater-Temperature control
    By jkcsanchez in forum Water Heater Forum, Tanks
    Last Post: 08-22-2009, 11:30 AM
  3. Water Heater temperature
    By kayre in forum Water Heater Forum, Tanks
    Last Post: 04-10-2009, 03:47 PM
  4. Water Heater - temperature erratic
    By Lynne Marie in forum HVAC Heating & Cooling
    Last Post: 04-11-2008, 05:37 AM
  5. Water Heater - temperature erratic
    By Lynne Marie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2008, 11:45 AM
