KBHOMEOWNER
OK, Internet savy, can following instructions...but don't know my plumbing and water softener terminology, so I'm dumbing it down for myself.
I have a Kenmore 625.393560 (350 Series), come into the garage two mornings ago - there's water on garage floor, not a tremendous amount but something has leaked (less than a gallon). Open lid on water softener, the water level is right up to level 7. Is the there a puncture in the tank? No. Oh, I see - water level in the tank rose up and simply came out of that approximately 3/4 inch diameter hole in the backside of the tank (at about level 7). Holy crap notice as well, I haven't added salt in a while, it was pretty much empty - there's basically a little salt and brown muck at the bottom of the tank. So I clean the garage floor with towels and start my on-line research.
Read the www.kenmorewater.com site. Read solution, read other posts that indicate - all indicate you need to clean the Venturi system and do the regeneration immediately button. Find nice Youtube video. Clean it exactly as shown (letter up on the floats, clean everything with warm soapy water). I also want to drain the water from the tank because I don't like the brown muck on the bottom. How the frick do you drain this thing, there's no drain valve at the bottom - but more importantly how do I uncouple this thing so I can tip it over in my yard (where there are no plants). So I bail it out with a orange juice container that I cut. Crap is it hard to get your arm to the bottom. Jury rig a stick with a 1 cup measure on the end and eventually I get almost all but a 1/2 inch of water. Wife starts bitching at me about taking the 1 cup measure. My arm is about to fall off as well. There are salt pellets around those other two tubes inside the tank (a black one with the salt level lines and a much fatter container/tube looks like made of fiberglass or something). Go to Home Depot - buy 5 bags of salt pellets. So basically what I've done...
Regen seems to take a few hours but appears to complete.
Next morning - water all over my garage floor again, this time a little more. HELP !!!
- Cleaned the tank as best I could (although there was still some pellets and brown watter at the bottom - simply couldn't get at it)
- Cleaned the Venturi system and put it all back (properly to the best of my knowledge)
- Poured salt pellets in, up to level 7 and reset the salt level
- Hit the Regen button and hold for immediate
