Thread: Deep well seal & conduit identification
    Default Deep well seal & conduit identification
    The galvanized conduit coming out of the seal is the house supply. What does the pvc conduit go to? Is this for venting?
    I need to loosen the seal so I can shock the well including the casing. I want to make sure that's not a 5' long vent pipe that's going to drop in the casing when I take the seal off!
    Secondly, Is this a two piece seal? If I loosen all four bolts is half of this thing going to fall down?
    BTW, The well was drilled in '98. is 220' deep with a 30' static level and an 8 yield. It's marked on the name plate.
    Is that good? I calculate needing to dump 1.5 gallons of bleach in my system to shock the entire house. 280 gallons in the well, 50 gallon hot water heater, 30 gallon tank, 10 gallons for the lines in the house. 2ppm of bleach.
    Is that right?
    I'm going away for a week and I plan to let it sit in the system all week.
    DIY Junior Member Harold Crawford's Avatar
    Sep 2013
    Michigan
    Getting cap off to pull lines to replace fpot valve
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    The pvc may be part of an emergency hand pump.
  1. Replies: 8
    Last Post: 02-25-2013, 06:01 AM
  2. When connecting 4" ABS sewer line to Cast Iron, how deep is deep enough?
    By Man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2012, 08:16 PM
  3. To Seal or Not to Seal the Stair Landing
    By chefwong in forum Remodel Forum & Blog
    Last Post: 02-05-2012, 05:35 AM
  4. Jumbo Wax Seal/Double Wax Seal?
    By SteveMar in forum Toilet Forum discussions
    Last Post: 08-23-2009, 08:44 AM
  5. Remove Well Seal on a Twin Pipe Deep Well
    By scarrie1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-04-2008, 04:25 PM
