Results 1 to 4 of 4
Thread: Splitting single cold water with double valve...legal?
    DIY Member jed1154's Avatar
    Feb 2008
    Texas
    Default Splitting single cold water with double valve...legal?
    I have a single cold water valve coming into a bar sink, and I want to add a tankless water heater. I see they make a 'double stop' valve that is essentially a dual outlet valve. Is this code compliant if I use this to split my cold line??
    You may want to go with a 1/2" supply for this one.
    http://products.eemax.com/EX3012T
    Feb 2008
    Texas
    The heater I had picked out actually uses 1/2" NPT...I was just wondering if it was cool to use one of those valves they put on for dishwashers...to split the cold line. Is that legit?
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Yes, if Iunderstand you correctly, it's OK to do.
  1. No cold water coming from my single handle Pfister lavatory faucet
    By anglii in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2011, 09:45 AM
  2. Single to Double vanity
    By mfl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2011, 05:20 PM
  3. No cold water in single valve shower!
    By DrNic in forum Shower & bathtub Forum & Blog
    Last Post: 05-29-2011, 07:47 AM
  4. Moen Single Handle shower- no cold water???
    By b00mstick11 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2010, 02:29 PM
  5. Single to Double sink water and drain?
    By smileyroget in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2006, 10:46 AM
