Results 1 to 2 of 2
Thread: What to do with a leaking Mansfield 160
    DIY Junior Member Tollerplumbing's Avatar
    Jan 2013
    WNY
    Default What to do with a leaking Mansfield 160
    I bought a 7 year old house with a Mansfield 160 in the basement. The former owner only used the house occasionally in the summer and I doubt the toilet has been flushed 50 times.
    Today I noticed water running every 5 minutes for about 10 seconds and traced it down to the toilet. I played with the flush valve and it stopped leaking, but I doubt it is a permanent fix.
    They sell replacement flush valves for $9 and flush valve seals for $2. Do I need a new flush valve, or is the seal likely to be adequate?
    Apr 2012
    New York, NY
    Most likely you just need to change the seal on the flush tower. (The least expensive solution, and it's usually all you need.) It's easy to do with the Korky 427BP replacement seal. See my responses 9 and 21 in this thread: http://www.terrylove.com/forums/show...Stops-Running/ The suggestion made by Redwood that I link to in response number 21 is a little trick for getting the seal on correctly. The guy I was helping tried the trick after not getting the thing to stop running after replacing the seal, and the trick worked perfectly, so all the discussion about new flush valves, etc., was totally unnecessary. All he did was replace the seal, and then use the trick to make it seat properly, and for a couple of bucks he was leak-free.
    If you need me to break it down more for you, just ask.
    Good luck and let us know how it goes.
    (Unlike the guy in that thread, you most likely do NOT need a new fill valve as well.)
  1. Mansfield Anti-freeze Hose Bib - leaking again after winter
    By mdenglund in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2013, 07:46 PM
  2. Mansfield 160 w/New flush valve and gasket is still leaking
    By dknight in forum Toilet Forum discussions
    Last Post: 10-18-2009, 02:31 PM
  3. Mansfield 300 series Silcock leaking
    By Rookie34 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-31-2009, 05:16 PM
  4. Leaking Mansfield frost-free faucet
    By Wild_Will in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2006, 02:18 PM
  5. Leaking Mansfield 700 series sillcock
    By pmoline in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-19-2005, 10:12 AM
