Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Rainbird sprinkler valve to be used for flush valve?
  1. #16
    Feb 2011
    NW Ontario, Canada
    Most of the precipitated iron either sticks to the sides of the tank or stays in suspension and goes to the iron filter where the media removes it. Anytime I manually flush the contact tank, it runs clear within seconds.
    My Banjo filter traps about a teaspoon of sand in a month so flushing it once a quarter works for me.
    I have my iron filter programmed to backwash 3 times a week. Once a quarter, I also do a few back-to-back manual backwashes at higher pressure. I open up the micronizer bypass for more GPM and jack the pressure to 80 PSI.
  2. #17
    Nov 2005
    Central Florida
    I've been wondering about this for years; this is the first definitive answer I've gotten. Good (I guess) to know that it's normal. I use a simple spun filter following the 120-gallon contact tank, and it has to be changed every 2 or 3 months. I wonder if the swirly contact tanks (http://www.apwinc.com/retention_tank.html) have the same problem? I may know in a few weeks.
  3. #18
    DIY Junior Member statin's Avatar
    Oct 2008
    Wisconsin
    LLigetfa, what kind of filter are you using? Backwashing three times a week seems like a lot? I was hoping to only backwash twice weekly at most. What have you done to determine needing the three times weekly? Do you have anything after the iron filter? One more question what are you using for on oxidizer?
    Mikey, what is the price of that contact tank?
  4. #19
    Nov 2005
    Central Florida
    Quote Originally Posted by statin View Post
    Don't know; mine came as part of a system. Call the vendor -- under "Contact Us" on the page I linked.
  1. RAINBIRD VALVE and L30 inlet pressure line
    By johnny wen in forum Irrigation / Sprinkler Forum
    Last Post: 08-30-2012, 09:47 AM
  2. Who makes the best Rainbird type sprinkler head?
    By ballvalve in forum Irrigation / Sprinkler Forum
    Last Post: 07-18-2011, 10:52 AM
  3. Rainbird valve problem
    By leeelson in forum Irrigation / Sprinkler Forum
    Last Post: 03-24-2010, 02:19 PM
  4. Chain from flush handle to flush valve
    By lkrides in forum Toilet Forum discussions
    Last Post: 11-17-2008, 05:44 PM
  5. Need sprinkler valve help
    By Nereus in forum Irrigation / Sprinkler Forum
    Last Post: 06-09-2007, 09:52 AM
