Results 1 to 8 of 8
Thread: Water Heater Space Problem
    DIY Junior Member Thomas D's Avatar
    Aug 2013
    GA
    Default Water Heater Space Problem
    The house we just purchased has 2 water heaters. One is almost new and is in the 1.5 story lever of the house.
    The other is 1985 model and we want to change it out. It is above the garage. The only way to get to it is up the pull down stairs. Ceiling joists are 24 inches on center. The water heater Rheem is 22 wide and 32 high and is 40 gal.
    Cannot find a 40 gal heater that will fit between the joist spacing and short enough to fit into the space due to the roof angle.
    Any ideas short of relocating the heater which would involve an electrician relocating the 220 line and plumber relocating the cold and hot lines?
    I have thought about going to a 30 gal heater which will fit, but am not sure if it will be enough hot water. I think the heater services the laundry and kitchen, which would be fine. Any way to tell what areas are serviced by this heater?
    Aug 2009
    South*East
    Turn the valve off on the tank and see where there is no water coming out of the hot faucets.
    John
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    A Reliance Lowboy measures 23" wide x 31.5" tall. It should work for you. You can find this brand at True Value.
    DIY Member ImOld's Avatar
    Jun 2013
    In the rumble seat
    Well, I know Lowes carries a Whirlpool 38 gal lowboy of the same dimensions as your Rheem because I pass by it in the store every trip.
    Aug 2013
    GA
    Quote Originally Posted by dj2 View Post
    23 in wont fit between ceiling joists which are 24 in on center. I did see a reliance low boy that was 22 x 30 but it was a 30 gal. That might be enough depending on what it supplies.
    Aug 2013
    GA
    Quote Originally Posted by ImOld View Post
    Will look tomorrow. Thanks. The only 38 low boy I see on Whirlpool site is 24 inches wide.
    Aug 2013
    GA
    Quote Originally Posted by johnjh2o1 View Post
    John
    Alas, there are no valves on either tanks hot water side. Have shut one off and will see where the lukewarm water is. With over 100 degree temps in attic it might take awhile. Hopefully, the old tank will be supplying the kitch, and laundry room. If so, then might just go to a 30 gal.
    Aug 2009
    South*East
    The valve will be on the cold side and that will turn off the hot water.
    John
  1. Space heater cord hot
    By BellPilot in forum Electrical Forum discussion & Blog
    Last Post: 04-07-2011, 10:46 AM
  2. Safer: Electric Space Heater Or Bathroom Heater/Exhaust Vent
    By Briandl in forum Shower & bathtub Forum & Blog
    Last Post: 02-15-2011, 12:40 PM
  3. What water heater for a limited space
    By Dom Z in forum Water Heater Forum, Tanks
    Last Post: 08-06-2009, 09:08 AM
  4. water heater replacement 1969 California home, with a foot craw space
    By chubyball in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-01-2009, 06:46 AM
  5. Conventional Water Heater minumum space needed?
    By jdgarza_tx in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-31-2006, 07:32 AM
