Thread: Partially Closed Shutoff
    DIY Junior Member essjay's Avatar
    Nov 2012
    Pennsylvania
    Default Partially Closed Shutoff
    Had 'annual' servicing done to combi boiler yesterday and tech could not answer my question....
    There is a shutoff ball valve on the baseboard heat supply side pipe of the circulator pump (3 zones, 1 pump) that I assume is for future isolation of pump in case it must be replaced. It is located prior to any zone valve and is only partially opened. My question as to why it is not fully open could not be answered. The tech stated that he sees alot like that but does not know why and would have to ask someone. Anyone know why these are only partially closed/opened on it seems alot of other systems this tech services?
    sj
    Hey, I'm Over 50. Multitasking is just my brain short-circuiting.
    Lazy service people who only move the handle far enough to get flow. if it is ahead of the pump, it could also be causing damage to the pump if it is not fully open.
    I have seen guys try to use a ball valve to control flow - this may be the case. ball valves should be either fully open or fully closed - any flow through a partially open ball valve will erode the ball and eventually render it useless
  1. joining ABS pipes partially under water
    By darren_t_johnson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2013, 03:50 AM
  2. partially blocked submersible pump
    By JAR8832 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-20-2012, 09:32 AM
  3. partially blocked hot water to shower
    By peltaz in forum Shower & bathtub Forum & Blog
    Last Post: 11-23-2008, 07:43 AM
  4. Partially slow running drains?
    By acalka in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2008, 06:03 AM
  5. Partially drilled into pvc
    By Sherie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-06-2008, 03:57 PM
