Results 1 to 9 of 9
Thread: Washing Machine drain-vent delima
    DIY Junior Member carltie's Avatar
    Aug 2013
    Boston
    Default Washing Machine drain-vent delima
    Hello,
    Re-positioning my washing machine . The picture below indicates the new high efficiency washing machine setup. I am using 2" pipe for the drain but I am not sure how to connect it to the main drain as the connection are very closely coupled with bends. I am also wondering if I need to have a vent and if so how to make the connection. Would AAV work for washing machine ? I live in Massachusetts so not sure if the code allows.
    Any help would be appreciated.
    Your real problem is that Massachusetts do not allow DIY plumbing. Briefly on your questions: No AAV for washers, washer must drain into an open standpipe that is trapped and vented. Your diagram indicates an unvented trap with a standpipe that is too short. It appears you have a vent available, but I'm pretty sure the connection the the main drain will have to be lower. Again, DIY is illegal in MA, you need to hire a plumber.
    Jan 2008
    It looks like you have plenty of hack work there already if the washer and kitchen sink are piped with 1-1/2" pipe. You cannot legally plumb there, and you have some re-work to be done. Assuming the fixture vents are installed correctly, 2" sink and washer drains should tie directly into the 3" line.
    Aug 2013
    Boston
    You can say that again - hack work indeed! Just bought the house and realized my delima. Previous owner cut a lot of corners. Not sure what you mean "cannot legally plumb there" Is there no way this job can be done? What about this setup below. Is the vent legal?
    Jan 2008
    What Gary was eluding to was that where you live, it is against state law to perform plumbing without a license.
    The vent must be vertical, and the vent take-off must be located at or prior to the point which the drain line turns downward.
    Aug 2013
    Boston
    Fair enough. I agree a licensed plumber would has to complete the job . Any thoughts on how much this re-work would cost me?
    No way anyone will even venture a guess on the cost. Several reasons, but a couple of reasons include the extent of the work than needs to be done has to be evaluated on site and local plumber rates vary widely from place to place. Your best bet is to get at least 3 estimates from local contractors. Talk to locals about their experiences. Keep in mind that some estimates may be very high because they really don't want the job. Also be leery of an estimate that is super low. Finally, don't waste you time trying to figure out how the job should be done. Let the pros determine that.
    Nov 2010
    Maine
    If I'm seeing the mess right it appears that both fixtures drain into a 4" x 1-1/2" sanitary tee that was cut into the cast stack. It needs to come out and be replaced with a 4x2 and both drains then need to enter the new line separately. It looks to me like around 500 bucks or so.
    Aug 2013
    Boston
    Great advise guys! Thanks a lot. Looks like the stack would have to be cut open and rectified after all. Seems like a major plumbing job.
  1. Washing machine/sink drain and vent
    By garrettgjp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2013, 08:38 AM
  2. New Washing Machine Vent Question
    By dennpad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2013, 09:59 PM
  3. Help with Washing Machine trap/drain/vent
    By schomeowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2008, 09:29 PM
  4. Washing machine and vent
    By jadnashua in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2007, 05:57 PM
  5. Washing Machine Drain- vent needed?
    By jdkimes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2006, 03:05 PM
