Results 1 to 8 of 8
Thread: Question about adding a new sink to my basement using existing line.
    DIY Junior Member ddaniels's Avatar
    Aug 2013
    Alberta
    Default Question about adding a new sink to my basement using existing line.
    Rookie question.
    I have a 1 1/2inch drain line that drains my kitchen sink on the main level of my house and runs through the basement into the ground. I need to know if I can add a bar sink to the exisitng drain. I have attached a photo to show my situation.
    Please let me know if this is possible or if you have any other suggestions.
    .Name:  Untitled.jpg
    Thanks.
    Darren
    DIY Junior Member Ottawa97tj's Avatar
    Aug 2013
    Ontario Canada
    Hang in there a pro will confirm soon but from what I understand you can't do it the vent would have to be above the highest fixture in the line, if nothing is above the kitchen sink then the vent would have to tie in there
    Not without a vent.
    When the upstairs drains, it will push air out of the trap below.
    Nov 2010
    Maine
    To do it right you would have to increase the drain size to 2" to the point the bar sink connects and properly vent the bar sink. An AAV may be allowed in our jurisdiction.
    Nov 2009
    Victor, MT
    An AAV won't protect against positive pressure (that air being pushed down from the sink above).
    Nov 2010
    Maine
    Hence the need to increase the drain to 2"
    Connecting the vent back to the drain line WOULD work, but it would also be illegal. It has to tie in at a point above the sink on the upper level. Positive pressure is positive pressure whether the drain is 1 1/2", 2", OR 3".
    If it were to be added to the waste stack, it would need to be done is such a way that no waste comes down the vent portion. It would need to be treated like an island fixture.
  1. Adding an additional drain waste line to an existing line.
    By hdmstng in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2011, 04:49 PM
  2. Adding New Sewer Line Under Existing Slab on Grade
    By Indie6 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-14-2011, 08:54 PM
  3. Adding a line from my existing well to a cabin
    By cookndngrl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-13-2011, 05:59 AM
  4. Adding a Laundry Sink to Existing Washer Drain
    By bradleonard in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-22-2010, 03:53 PM
  5. Adding a Tee to an existing 3 inch PVC Line
    By rossirj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2007, 09:22 AM
