Results 1 to 15 of 25
Thread: Water Heater only Luke Warm
Threaded View
    DIY Junior Member Konowl's Avatar
    Aug 2013
    ottawa
    Default Water Heater only Luke Warm
    My water heater is only putting out luke-warm water. I put an OHM reader to the upper element and lower element at 1k OHM and both needles moved to infinity so I'm assuming both elements are ok. I just turned the heater on and the upper element is currently on but the lower element is not.
    I should note that this happened right after I replaced my well pump. I could hear a dripping when I emptied the pressue tank and couldn't identify where it was coming from. Waht I think might have happened is that due to no pressure in the system, the hot water tank could have lost a bit of water. After I turned everything back on, the hot water got REALLY hot - hotter than it's ever been - then went luke-warm. Sounds like the upper element burning out, right? So why is the multi-meter still showing movement. Maybe it's the thermostat?
  1. Bosch 125BNG gas water heater-Luke Warm water
    By westp1234 in forum Tankless Water Heater Forum
    Last Post: 12-14-2011, 09:56 AM
  2. Luke warm water on cold mornings
    By rank amiture in forum Water Heater Forum, Tanks
    Last Post: 12-10-2011, 04:03 AM
  3. luke warm water
    By dennislewis in forum Shower & bathtub Forum & Blog
    Last Post: 01-03-2010, 09:27 AM
  4. luke warm water at bath
    By kmp-fxsts in forum Shower & bathtub Forum & Blog
    Last Post: 01-30-2007, 10:57 PM
  5. moen luke warm water
    By juicer in forum Shower & bathtub Forum & Blog
    Last Post: 01-27-2007, 02:35 PM
