Results 1 to 7 of 7
Thread: Drain size for washer in Canada
    DIY Junior Member MIKE007's Avatar
    Aug 2013
    Montreal
    Default Drain size for washer in Canada
    My vertical drain is 1 1/2. There is a dishwasher + kitchen sink on the first floor and a washing machine in the basement connected trough a back flow valve after the p-trap. I newer used both washing machines at the same time. Is this diameter fine for both machines at the same time or I need 2"?
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    You need 2". Why is your drain 1-1/2"?
    maximum hydraulic load (fixture units) drained to a 1-1/2" soil or waste stack - 8FU
    maximum fixtures units from any one storey drained to a 1-1/2" soil or waste stack - 5FU
    kitchen sink = 1.5 FU
    dishwasher = if separately trapped with 1-1/2" trap - 1FU if connected to sink or garbage disposal - 0FU
    clothes washer = 1.5FU with 1-1/2" trap
    assuming all piping and venting is proper - your arrangement meets code requirements
    Aug 2013
    Montreal
    Thank you for your answer.
    Yakima WA
    I believe Canadian codes are different in that they have not upped the drain sizes as the US has. Your 1-1/2" may be legal, but 2" sure would be better.
    30years plumbing 10years plumbing inspector Bill Shack's Avatar
    Mar 2014
    montreal quebec Canada
    I disagree, The pipe must be at least 2 inches, Further the Quebec amended canadian code is about to change so that all laundry machines connection are minimum 2 inches.
    the Ontario Plumbing Code is also changing the minimum drain size for a laundry pipe to 2"
  1. pipe size /max length of run for kitchen, Canada Code
    By Philbert in forum Canadian Plumbing Code Questions
    Last Post: 06-29-2013, 07:47 AM
  2. floor drain, Canada
    By christoff in forum Canadian Plumbing Code Questions
    Last Post: 06-20-2010, 04:48 AM
  3. floor drain, Canada
    By christoff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. Clothes Washer drain size
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2010, 11:47 AM
  5. Disparity in replacement washer drain hose size
    By Timneh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-30-2009, 06:41 AM
