Results 1 to 8 of 8
Thread: No Hub Cast Iron
    DIY Junior Member Tucker7100's Avatar
    Aug 2013
    Mokena IL
    Default No Hub Cast Iron
    Is it legal to use 3" and 4" no hub cast iron piping in underground parking garage that is above ground of course for storm water applications in Chicago? Current piping is SV bell and spigot lead joint piping but all rotted out. I want to use no hub because of very tight areas where pouring a lead joint is impossible due to carbon steel boiler piping.
    No-hub would be legal in Seattle. Maybe a Chicago plumber here will know.
    I haven't been is Chicago for over 40 years, but I am sure by now that No-Hub would be approved.
    Nov 2010
    Maine
    Ah, Illinois has some pretty stricken plumbing laws. They have their own code. If ou don't have an Illinois plumbing license I strongly advise you to find a plumber that does. Especially commercial work.
    Aug 2013
    Mokena IL
    Ill have to look in code book. Its kinda unclear because its a parking garage and also not sanitary sewer.
    The last parking garage I did for the Boeing Credit Union was all no-hub, above and below ground. But that was near Boeing Field in Seattle.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    2 sources to ask:
    Your local building department OR an experienced plumber.
    Nov 2010
    Maine
    These guys can help you out.
    Storm drainage is almost always handled by plumbers and is generally included in the plumbing code.
    http://www.idph.state.il.us/envhealth/plumbing.htm
  1. Cast Iron VS PVC for DWV
    By Steven Gaffin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-27-2012, 09:28 PM
  2. cast iron fitting installed in cast iron soil pipe
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2009, 06:20 AM
  3. PVC into cast iron
    By blue96bird in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-05-2006, 04:50 AM
  4. cast iron
    By woe in forum Toilet Forum discussions
    Last Post: 01-26-2006, 08:51 AM
  5. ABS to Cast Iron Hub
    By DVDiva in forum Remodel Forum & Blog
    Last Post: 09-12-2005, 02:54 PM
