Irrigation pump loses prime overnight
sschnei
Texas
Hi, new to forum and have a pump priming issue.
I have a 1 HP Sears pump to pull water from lake for lawn and landscape irrigation. This summer, the pump began losing prime overnight. When I refill the housing, the pump runs fine.
There are no visible signs of water leaks. So, suspecting a leak somewhere on the intake, I inspected and replaced the all the PVC intake piping, even though I found no evidence of a bad joint. I inspected the swing check located on the inlet and it is clean and clear, but it still loses prime overnight.
Now I’m thinking the shaft seal may be bad… but it does not leak water during operation???
I can’t think of anything else to look for. Does anyone have suggestions?
Many thanks in advance.
Craigpump
Hook up an air compressor and charge the pump and suction line with air. Your leak will be where the bubbles are.
sschnei
Texas
Thank you for the responses. Interesting that in the 5+ years it has never had a footvalve on it.
Based on your input, I have already purchased a footvalve. I'll keep you posted as to how it works out.
DonL
Houston, TX
A Foot valve is a good thing.
It will keep the pump from needing to run dry every time you start it.
You probably have a small leak on the pump seal. Or the suction connection at the pump.
The foot valve should help to mask that problem.
Good Luck.
sschnei
Texas
I recieved my footvalve yesterday, plan to install today. Had an interesting thought overnight.
After I install the foot valve how do I drain the intake piping before winter to prevent freezing the pipes?
DonL
Houston, TX
You should be able to start the pump and pull the inlet out of the water and raise it up high, until water stops coming out of the pump outlet. It is best not to let it run dry for very long.
Good Luck.
Wet_Boots
Sprinkler Guy
Metro NYC
PVC suction piping can include a union, to allow you to pull out the section of pipe with the foot valve. The O-ring seals in the unions are reliable enough to not be a source of suction leaks.
DonL
Houston, TX
Seems like just removing the Valve would be easy enough.
That can be easier said than done, depending on the pipe type.
sschnei
Texas
Update...Installed foot valve on Saturday, primed pump and let it sit overnight. Sunday morning I started the pump and water came out the sprinklers without delay. I like that! My lawn and garden like that!!! Hopefully winterizing will prove to be no big deal.
Thanks for all the input from the forum.
DonL
Houston, TX
Good Work.
Enjoy.
