Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Can Screw In Fuses be Safe If Sized Correctly?
  1. #16
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Was this just a test ?
    DonL, No, this is a subject I've wondered about, and I thought the experts here could help!
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
  2. #17
    If close control of the maximum current in a circuit is required, a fuse will typically protect things quicker than a circuit breaker, and often, be more reliable at that task. But, it is certainly easier to throw the CB back on than to go find the proper fuse should it eventually die. Both fuses AND CB can fail over time from corrosion, or thermal stress, vibration, and other things. So a failed one isn't necessarily an indication of overload. My guess is that a failed CB is more likely to still pass current than a failed fuse, but failure isn't all that common on either.
  1. Fuses getting very hot in Fusebox
    By Ala Roshdieh in forum Electrical Forum discussion & Blog
    Last Post: 01-31-2013, 05:55 PM
  2. custom sized tub??
    By doug81 in forum Shower & bathtub Forum & Blog
    Last Post: 02-12-2012, 06:59 PM
  3. fuses
    By jimbo in forum Electrical Forum discussion & Blog
    Last Post: 08-01-2011, 07:22 PM
  4. How old are these fuses?
    By Phillbo in forum HVAC Heating & Cooling
    Last Post: 07-14-2009, 06:19 PM
  5. What Fuses?
    By molo in forum Electrical Forum discussion & Blog
    Last Post: 07-02-2007, 05:36 PM
