Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Circuit Breaker trips same time every day
    DIY Junior Member Art Caballero's Avatar
    Aug 2013
    Spring, TX
    Default Circuit Breaker trips same time every day
    I have 2 separate 15 Eaton ArcFault Breaker Type BRAF one for light and other for receptacles. They going to bedrooms and trips every morning at same time while were all asleep. This is odd.
    House was built in 2007. Do not have anything plugged in but lamps and radios that could cause tripping. Has anyone had same problem?
    Does it happen when the alarm on the radio goes off (should it have an alarm)?
    As a test, unplug everything that is plugged in and see if it still happens.
    At some point, when AFCI were mandated, they had some issues and tripped when they shouldn't. I may be a replacement may solve that.
    Jun 2007
    North Carolina
    Who are you going to call Ghost busters
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Ghost busters? Maybe a capacitor bank being switched in by the utility as the load ramps up in the morning is injecting enough noise to trip your breakers?
    Mar 2011
    Houston, TX
    How can you tell it trips at the same time if you are asleep ?
    Do you have a automatic setback thermostat that is set for that time ?
    Good Luck.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Quote Originally Posted by Art Caballero View Post
    Ghosts are hard to track down. Start with unplugging and turning off everything that is on those two circuits and see if they still trip.
    Aug 2013
    Spring, TX
    Bluebinky, You are probably right. I tested both breakers last Sunday morning around 9:00 and problem went away until last night. Woke up last night for some reason at 5:25, just in time to have problem happen again.
    Went out to rest breakers at panel and guess who was up resetting his breakers. My neighbor. They are having same problem. Will contact utility company Monday.
    Aug 2013
    Spring, TX
    DonL, I have an automatic timer in my head. Always waking up early. It is genetic.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by bluebinky View Post
    Thanks for the concept. Lord knows troubleshooting is a pain. And if the culprit is the utility, I would be slow to consider that.
    I'll file that one away.
    Mar 2011
    Houston, TX
    Could be a Ham Radio Operator on your street making his morning schedule.
    I have heard that RF on some bands can really play tricks with some Arc Fault Breakers.
    Some of the newer and better models have better RF filtering.
    Mar 2011
    Houston, TX
    Did you find a cure yet ?
    You can Google "Eaton AFCI ham radio" and find some interesting facts about the Eaton AFCI.
    I would consider replacing the Eaton with a Square D.
    Have Fun.
    DIY Senior Member Murphy625's Avatar
    Jul 2013
    Michigan
    Umm.. I don't think so.. the tower would have to be inches from his wiring or blasting enough power for aliens to pick it up...
    Mar 2011
    Houston, TX
    Quote Originally Posted by Murphy625 View Post
    Many Hams do not have towers. They are not allowed.
    They disguise Flag poles and use attic antennas because of Home Owner Associations.
    2000 watts can cause problems 1/4 -1/2 mile away, with just a simple dipole antenna.
    Jul 2013
    Michigan
    2000 watts, even coming from a full wave or half wave antenna, would induce such a miniscule signal at 1000 yards that I have serious doubts it could possibly interfere with a device that is looking for a low frequency kilohertz signal inside household wiring.
    Now, maybe if you stuck the antenna in the middle of the house and wrapped the romex wire around the home you might get something....
    I guess stranger things have happened and I'm not saying it is impossible, but I would have to see it with my own eyes before I bought into that... We're really talking about what amounts to a radio signal, and a weak one at that, interfering with a land-line for all practical purposes.
    Now, if one were to suggest it could interfere with a cell phone or a tv signal or a wireless baby monitor or something, that would be more inline...
    But then, RF signal propagation is not really my cup of tea....
    Mar 2011
    Houston, TX
    Here is a test that a Ham did, Running 100 Watts, and his neighbor about 400 feet down the street let him do some testing.
    http://www.youtube.com/watch?v=JsILD0Fce1s
    The audio is a bit low, but it shows what happened.
    This panels AFCIs were affected by the 17 Meter Band, with only a 100 watt transmitter.
  1. Gas Furnace Fan Trips Breaker
    By plumbtired in forum HVAC Heating & Cooling
    Last Post: 12-12-2009, 04:51 AM
  2. Circuit Breaker Trips same time every night
    By peter61 in forum Electrical Forum discussion & Blog
    Last Post: 08-11-2008, 07:26 PM
  3. Outside Breaker Trips
    By gmrules in forum HVAC Heating & Cooling
    Last Post: 07-06-2008, 04:54 PM
  4. AFCI Circuit trips when I turn on lights
    By Keith Wolf Ent in forum Electrical Forum discussion & Blog
    Last Post: 06-23-2008, 08:15 AM
  5. pump trips breaker
    By lhogle in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2006, 06:15 AM
