Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Just cleaned salt tank now what ?
    DIY Junior Member theboneman21's Avatar
    May 2013
    New Brunswick
    Default Just cleaned salt tank now what ?
    Hi Gang
    So just cleaned the tank put back together and dumped salt in
    Do i have to add water or will that happen at the next regen on account of the float ?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    You should add about 3 gallons of water.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by theboneman21 View Post
    Depends... did your salt tank have brine in it before you cleaned it? Most softeners add the water at the tail end of the current cycle for the next regen cycle. In that case you need to add the water before the next regen.
    May 2013
    New Brunswick
    ok it did have brine in it. will add water
    thanks folks
    May 2013
    New Brunswick
    down the brine well or the actual tank ?
    Central Florida
    It all winds up in the same place. Just dump it in the tank.
    Down the brine well so you don't cause a salt bridge. If you don't have a brine well, then down along the inside of the tank so you don't get anymore salt wet than you have to.
    Central Florida
    I stand corrected; thanks, Gary.
    While we're on the subject of brine tanks, I've got a couple of questions:
    1) The brine level in my tank decreases over time. No matter where it starts out, it eventually settles at about 3-4" deep. It looks like it draws brine (at BLFC rate?) until the tank is empty, then later refills at the BLFC rate -- 3 gallons total. Is this correct?
    2510 control has 0.5gpm BLFC, 2.4gpm DLFC, and is set for:
    10 minute backwash (At max flow pump will support, up to DLFC rate.)
    60 minute brine & rinse (Brine at BLFC rate until tank is empty? Then rinse at DLFC rate.);
    6 minute rapid rinse (At DLFC rate.)
    6 minute refill (At BLFC Rate.)
    All hose connections are secure, no leaks obvious.
    2) There are bold-face instructions in my 2510 manual saying "IMPORTANT -- SALT LEVEL MUST ALWAYS BE ABOVE BRINE LEVEL IN BRINE TANK". Why? Just to ensure completely saturated solution?
    Last edited by Mikey; 08-26-2013 at 07:11 AM. Reason: Noted DLFC rate limited cycles
    No brine tank will ever be totally out of water, there is always at least a half inch or more that can not be sucked out.
    Decreasing water level is probably due to a wicking action of the salt - soaking up water into it. Or a small water leak in the bottom of the tank that hasn't been found yet. lol
    Yes the BLFC dictates the gpm of both brine draw/slow rinse and refill.
    Backwash and rinse cycle positions of the control valve are controlled by the DLFC.
    Salt above the water line at the end of refill insures a full saturation brine but, the caution is more to keep softener owners from allowing their softeners from running low or out of salt; which causes less than fully saturated brine and that causes insufficient capacity to be regenerated. That causes hard water breakthrough of the resin before regeneration. That requires regenerating the resin at its max salt dose per cuft (usually 15 lbs/ft) and usually two of them are needed.
    Nov 2010
    Ocala, Florida
    I don't believe this is the case. If this were true, than it would not matter which way the flow control was positioned within the valve.
    Central Florida
    The FC button is basically a washer with a hole in it, right? I've always thought the directional requirement was related to flow rate, not flow -- i.e., in one direction a 0.5 button will pass 0.5gpm, but it the other direction the flow rate is indeterminate, but there will be a flow. There's very little information that I can find on these things.
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by Mikey View Post
    You are correct. In Fleck, Clack and EcoWater valves (most likely all other valves), the BLFC is allowed to "float" or move inside the FC area. Once the unit goes into a fill cycle, the water flow pushes the FC into it's seat and only allows water to pass through the center hole. During the brining/slowrinse cycle, the FC can move so brine can flow around the FC as well as through the center hole. IMO, the FC in no way controls the flow for the brine/slow rinse. If it did, it would not matter which way you installed the FC nor would it be placed so it has movement.
    Central Florida
    Excellent; thanks. I used to have a cutaway diagram of the 2501 showing flows for all cycles, but it has temporarily (I hope) escaped.
    Jan 2012
    California
    Mialynette, Correct, the Brine line flow control on all Fleck and Clack valves is directional. They flow around and through the refill control during brine draw, they fill only through the hole during refill. The Brine line flow control buttons are in a guide cage that allows them to move back and forth depending on if the system is in brine draw, or refill.
    Even the largest softeners use this same design. Fleck makes brine flow controls up to 20 GPM as a standard item. These are direction flow control.
    Nov 2010
    Ocala, Florida
    Thank you for the confirming. The last time I said the same thing I was chastised by your friend and mine.
  1. Changing salt tank - any possible negative ramifications
    By theboneman21 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-25-2013, 09:29 AM
  2. Dead frogs in salt tank!
    By Carol Brasby Clarkson in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-08-2013, 09:13 AM
  3. Cleaned the brine tank, Now no soft water?
    By thegoldenhand in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-19-2012, 11:01 AM
  4. Cleaned salt barrel, got it all cleaned out and now....
    By bsa_bob in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-22-2011, 11:20 AM
  5. salt forming around outside of brine tank
    By chris fox in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-27-2010, 08:19 PM
