Thread: Pipe Size Question - PEX to Galvanized
    DIY Junior Member jgold47's Avatar
    Nov 2010
    Detroit, MI
    Default Pipe Size Question - PEX to Galvanized
    House was built in the 20's. Piping going to second floor bathroom (shower/toilet/sink) is galvanized. At some point before we bought the house, most of the basement feed lines were re-plumbed using PEX and crimp rings.
    My question is twofold...
    Most of the supply lines are 3/4", dropping to 1/2 inch to feed the kitchen, first floor bath, hose bibs, etc... for some reason, they also dropped to 1/2" to feed the 2nd floor lav, dropping to 1/2" and connecting to 3/4" galvanized heading up stairs.
    Question 1. Is there any reason to downsize the supply to 2nd floor lav? Or was the installer just sloppy? Would upsizing to 3/4" make a difference? The water pressure is ok, not great, and cant use more than one item at a time.
    Question 2. How do you switch out PEX like this? Can the rings be removed preserving the pipe, or am I looking at having to replace entire sections? I've never worked with PEX, so I would have to invest in all of the tools, but I also don't know any of the rules for working with it.
    Thanks in advance!
    http://www.terrylove.com/watersize.htm
    Normally you can run two plumbing fixtures on 1/2"
    A bathroom set would need 3/4" on the cold and 1/2" for the hot.
    Nov 2010
    Detroit, MI
    thanks Terry - Any issues with upsizing the feed lines to the upstairs? Given that they are ancient and galvanized? shouldnt change the line pressure just the flow right?
    DIY Junior Member Cody Smith's Avatar
    Oct 2013
    Colorado
    Is there a difference between Rifeng PEX and others? I've found better prices on Rifeng, but I don't want to get involved with 'cheap' lines. I've found some prices here if you're not familiar.
  1. Galvanized pipe question...
    By fatdaddy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2009, 04:14 PM
  2. upgrading pipe size question
    By jjfta in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-29-2007, 07:05 AM
  3. question about galvanized pipe
    By willl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2007, 10:36 AM
  4. pipe size question
    By Gary Swart in forum Irrigation / Sprinkler Forum
    Last Post: 04-21-2007, 08:04 AM
  5. Pipe Size Question
    By bpolson2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2005, 11:24 AM
