Can you identify this control valve?
ryroo
Utah
This was taken from a community college, it was used 3 years then they replaced with a larger system. I have 2 of these identical control valves with the brass head attached. I cannot find make/model information anywhere that positively identifies this. Can anyone help? photo 3-1.jpgphoto 1.jpgphoto 1.jpgphoto 5.jpg
the box this is mounted on has PN 40278
Under the main timer I can read "serial No 71101-005.000-0004c00" but it is identical on the second unit, so i'm not sure what that is identifying.
Thanks.
Akpsdvan
Alaska
Fleck 2900 commercial valves that are set up as softeners or potassium permag units.
The one in the photo is part of a lock out system, there is a master control unit some place that is not on the valve control.
ditttohead
Water systems designer, R&D
Ontario California
Pre-2006 Fleck 2900 electromechanical valve. The valve was re-cast as a single piece in the middle of 2005. A remote meter or other piece is missing as stated earlier. Probably a softener valve, it is set up for a 24" diameter tank (15 GPM DLFC). In that time frame, system 7 (twin alternating) or system 6 (series regeneration) were very common.
It appears to be in decent condition. It would make a great rental unit.
