Thread: heating upstairs zone works, downstairs doesn't - New piping
    DIY Member philtrap's Avatar
    Jun 2013
    Long Island, NY
    Question heating upstairs zone works, downstairs doesn't - New piping
    Folks,
    I just fired up my TT-110. The upstairs zone works fine. The downstairs (the one to the left) doesn't. The pipe above the valve hardly gets hot. Even when the circulator pump is on and the the second zone is closed. The Diff Bypass valve is set properly and water is not flowing back thru it. Something isn't right. I check and the zone valve is working. I even tried it manually. The flow goes up.
    I'm thinking the down stairs tee may be too close to the elbow to the left. I've see the rule of 12d. I can fix this, but do you think that's the problem. I don't want to do that work if it's not the problem. The zone valves are 4d apart.
    Any input would be greatly appreciated.
    Sorry about the photo being sideways. I tried to fix it with no luck. Up is to the left
    It's more common to have air in the higher level, but it doesn't take much to block flow through a loop...first thing I'd do is try to purge air from the system again.
    Jun 2013
    Long Island, NY
    Thanks jadnashua!! I re-purged again and one large burp and now all is fine now.
  1. 2 zone system-no heat upstairs-Boiler doesn't fire when that zone asks for heat
    By MrBostn in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2012, 08:33 AM
  2. Converting a manual switch heating zone to a thermostat heating zone
    By breilly629 in forum HVAC Heating & Cooling
    Last Post: 03-12-2010, 01:04 PM
  3. Toto ADA/upstairs downstairs questions
    By notmyfield in forum Toilet Forum discussions
    Last Post: 08-26-2009, 12:00 PM
  4. Smell after upstairs shower in Downstairs bathroom????
    By harheath in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2005, 06:34 PM
  5. Upstairs don't flush, downstairs does
    By catlind in forum Toilet Forum discussions
    Last Post: 02-24-2005, 08:40 PM
