Results 1 to 8 of 8
Thread: P-Trap to vent minimum, Weir to Vent question
    DIY Junior Member mahuska's Avatar
    Aug 2013
    iowa
    Default P-Trap to vent minimum, Weir to Vent question
    When sizing the weir to vent minimum on a P-trap is it measured from liquid edge in trap to start of vent inner diameter (=> than 2X trap arm diameter)?
    Nov 2009
    Victor, MT
    It is measured from the liquid edge to the start of the vent, but it is impossible to not meet code requirements given the configuration of the fittings available. Set that quandary aside and move on to the next one.
    Aug 2013
    iowa
    I have a tight shower location using a Kerdi line drain and if you use 2 pipe diameters as the minimum then the weir to vent distance is 5.75. If I just put the P-trap right on the 2" tee the distance is 3.75.
Size:  60.2 KBName:  too close.jpg
    Apr 2012
    New York, NY
    Quote Originally Posted by mahuska View Post
    I don't know what your pipe size is, but the minimum vent distance is never going to be 5.75. It's 2 pipe diameters -- inner diameter. 1-1/4" pipe will be 2.5" minimum. 1-1/2" pipe will be 3 inches. 2 inch pipe will be 4". 3 inch pipe will be 6 inches. See page 3 of this document: http://www.klickitatcounty.org/build...andout0411.pdf One thing that is slightly confusing about that document, however, is that it says the minimum "trap arm" distance is whatever, but it illustrates the measurement for meeting code the correct way, then illustrates the "trap arm" as a different distance. The measurement you want is the illustration that shows the distance as being from the inside of the weir to the outer wall of the vent. not the "trap arm" markings under the connection points.
    Aug 2013
    iowa
    Ok inner diameters make a lot of sense. 2 in pipe for a shower.
    Name:  2013-08-24 09.32.34.jpg
    Unless you have an "anal retentive" inspector with a ruler, no one will ever check it , at least none have ever turned my installations down even with a trap tight to the tee.
    Don't you just love idiots who post a long gibberish filled post in a foreign language, and then repeat it several times to be sure we don't miss it?
    Aug 2013
    iowa
    I feel that I missed something
  1. P-Trap/Vent question for new washing machine
    By tkram01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2013, 05:48 AM
  2. Vent/trap/kitchen question
    By MRI Vato in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2012, 11:38 AM
  3. Minimum Slope for Heater Vent
    By weaver in forum Water Heater Forum, Tanks
    Last Post: 05-24-2010, 05:52 PM
  4. Best Trap to vent Distance for Shower vent
    By Rocknroj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2009, 06:08 AM
  5. Toilet House Trap Vent Question
    By iliketominidisc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2008, 06:08 AM
