Results 1 to 6 of 6
Thread: Moving toilet 1-2 inches
    DIY Junior Member Nlminio's Avatar
    Aug 2013
    Nj
    Default Moving toilet 1-2 inches
    I have a toilet installed and I just put up the bathroom door and realized that the door is just shy of clearing the toilet by about an inch. Is there any way to simple move te toilet over a little bit so the door will clear?
    Generally, no. It may not be hard, but it would involve either access from below or tearing out part of the floor to move the drain pipe. A design consideration might be to replace the door with a pocket door, then there's no swing to deal with. Or, a surface sliding door.
    Yakima WA
    Swinging doors are a real space waster in a small bathroom. I faced this problem many years ago and solved it with a pocket door. When I added a bathroom in my basement, I did not want to use much space and it was a pocket door to the rescue again. This would be a very wise alternative to moving the drain.
    Is there space behind the bowl now that can be used?
    If so, then you may be able to move the drain.
    If you have a 4" drain, then you can fudge it back some.
    Though it may be easier to find a shorter in length toilet too if you have to move the entire drain.
    There could be several possibilities but we would actually have to see it determine which, if any, would work for you.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Is the toilet elongated by any chance?
    If it is, consider changing it to a round toilet.
  1. Moving a Toilet Drain a few inches
    By rockyqq in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-15-2013, 11:05 PM
  2. Moving a Toilet 3 inches sideways.
    By Troy_SLC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-13-2012, 11:19 AM
  3. Need help moving toilet a few inches
    By randalsw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-07-2010, 06:18 AM
  4. Moving toilet four inches
    By Lina in forum Toilet Forum discussions
    Last Post: 07-12-2008, 03:32 PM
  5. Moving toilet 4 to 6 inches to the side?
    By MOV in forum Toilet Forum discussions
    Last Post: 02-05-2006, 12:15 PM
