Thread: move vent wall back 12"
    DIY Junior Member rcm650's Avatar
    Aug 2013
    California
    Default move vent wall back 12"
    I got a question about moving my vent back by 12" to accommodate an extended shower. Help!
    I have a sketch of what is now and how I want it to be.....I have very little space to work in.....Thanks...rcm650
    Jan 2008
    You did not specify, but the shower trap and drain must be 2". Your plan will not work because the dry section of vent cannot be horizontal nor can a sani-tee be used on it's back. You will have to move the drain and the vent.
    There is no way your design would EVER be approved. You are essentially installing the sanitary tee backwards. The sanitary tee is NOT on its "back" it is on its "face", which is even worse.
  1. Can I vent come off the back of a 2" tee?
    By jer4242 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2013, 04:53 PM
  2. DWV Piping Dilemma from Adding wall-mounted toilet on one side of back to back setup
    By DIY_Steve in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2013, 09:19 PM
  3. wall mounted Kohler & Toto Aquia back to back
    By Chaosherder in forum Toilet Forum discussions
    Last Post: 10-21-2012, 08:09 PM
  4. Can one toilet carrier hold back to back wall hung toilets
    Last Post: 06-20-2012, 11:17 AM
  5. Can I use "in wall vent" instead of thru roof for shower?
    By hawksnest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-17-2006, 06:48 PM
