Lkstaack
I recently purchased and installed a Toto Ultramax II because I really liked the regular Ultramax I had. I found that they were quite a bit different in appearance and perfomance even though their descriptions were similar. Specifications indicate that they are both standard size with elongated bowls. However, the Ultramax II is taller with a smaller and more round bowl. Is this typical?
The model numbers for the two toilets are:
-Ultramax: MS854114SG#01
-Ultramax II: MS604114CEFG#01
Performance wise, I find the Ultramax II to be quieter and better at rinsing the bowl. However, it isn't as powerful as the Ultramax with the G-Max valve.
