Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: Separating Ground & Neutrals to Create Subpanel
  1. #16
    Mar 2011
    Houston, TX
    I really do not like the Idea of Auto Switchover when it comes to Generator Power. Unattended operation, is one big reason.
    In a home it can cause Lock Rotor conditions on anything with a compressor, and as JW pointed out stall the Generator or trip its breaker. Then you have even bigger problems, and can end up with nothing.
    It is not that much work to manually start the generator and switch loads to only what is needed.
    I use properly rated extension cords to power only the needed items. It saves fuel and I can suffer a bit until a Hurricane has passed.
    People are spoiled now a days, To each his own.
  2. #17
    DIY Senior Member Rich B's Avatar
    Sep 2008
    New Jersey
    You have got to be kidding here......In my area after millions of people suffered thru some severe storms over the last couple years.....Homeowners are buying generators at a very high rate and a very large percentage are larger units with Automatic Transfer Switches....and yes they now offer load shedding modules and the installs are not simple.....The company I work for services...sells....repairs.....and has installed hundreds of units......No way the average homeowner wants to do anything but pick up the phone if their generator does not work in a power failure.....Our phones never stopped ringing in a Storm like Hurricane Sandy......except during the actual event when everyone was hunkered down....Our commercial accounts are even more demanding and we service hundreds and hundreds of machines and switchgear......
  3. #18
    Jun 2007
    North Carolina
    I have two generators and use cords when needed. I do not have any type of transfer switch. Cord from generator to appliance or lamp.
    What would people do in case of a solar flash?
    gee no tv tonight.
  4. #19
    Sep 2008
    New Jersey
    What you and I do at home in a power outage is not the issue...
    What others request and are willing to pay money for.....is what I am speaking about...
    What about Essential services.......Like Police....Fire....Emergency...Health care providers.....Hospitals...
    They ALL have backup power with automatic transfer switches.......Some have redundant systems
    We have clients that spend thousands and thousands of dollars so they are never without power and they are data centers....
    After Hurricane Sandy they were so paranoid about possibly losing power in another possible storm they went on generator power before the storm and had us put men on site 24/7 until well after the storm......They even have backup machines in place to backup their backup!!! We have one in our yard now for one of those companies.....they have no room so we have it.....500KW unit on a trailer.....just for them incase their regular unit were to fail.....
    Money talks......
    So why should a homeowner not have the option of having the same capability....They do and if they are willing to spend the money for a proper install it gets done....
  5. #20
    Jun 2007
    North Carolina
    Quote Originally Posted by Rich B View Post
    Here-in lies the truth of the matter. The big problem is most don't know how to do a proper install
  6. #21
    Mar 2011
    Houston, TX
    Money talks......
    I worked on 3 phase switchgear but would not think of using it on my Home.
    Or a Changeover that I have no control over, unless I am home when "It tries to start". What happens if it does not start ?
    You still have nothing, and it can Pop electronics in your home. Seen electronics on oil rigs that fried because the Gen would not Gen. It can cost Millions of dollars when that happens.
    Even Natural Gas may not be available.
    You are correct Money talks, and fools fall for BS. I am not sold.
    Like I said people are getting lazy.
    As long as the Beer stays cold you should be good. Just buy or make Ice.
  7. #22
    Mar 2011
    Houston, TX
    Exactly.
    That is very True.
  8. #23
    Sep 2008
    New Jersey
    JW......We do not do installs anymore....All home units are done by contractors who use licensed electricians and plumbers with permits and inspections. Or by some electrical contractors who are licensed. I know of very few problems with any of these installs but truthfully we have seen many improper things passed. We come across things all the time especially in the area of fuel lines and plumbing. The electrical end not so much.
  9. #24
    Sep 2008
    New Jersey
    Well the average homeowner does not have 3 phase power and it is not all that much different than single phase anyway...So whats the big deal...
    You still have nothing.
    When power fails the only way a Transfer switch can operate is when your generator starts and makes AC power to energize the switch...
    If it doesn't start.....you failed to properly maintain your generator....and modern ATS equipment is mostly PC boards and an operator. Not many relays and timers like the old stuff.....and are not electrically held....like the old stuff that lasted for years and years anyway...
  10. #25
    Sep 2008
    New Jersey
    Your objections to modern equipment make zero sense....To each his own....
  11. #26
    Mar 2011
    Houston, TX
    That is why I run my beer cooler on Solar power.
  1. Subpanel neutral/ground isolation
    By Homeownerinburb in forum Electrical Forum discussion & Blog
    Last Post: 01-15-2012, 04:50 PM
  2. Supplying ground to old subpanel
    By rerickson in forum Electrical Forum discussion & Blog
    Last Post: 05-19-2010, 05:26 AM
  3. Subpanel Neutral & Ground On Same Bar?
    By slimjim43 in forum Electrical Forum discussion & Blog
    Last Post: 06-23-2009, 10:58 AM
  4. 25v on my neutrals
    By docaudio in forum Electrical Forum discussion & Blog
    Last Post: 12-03-2008, 05:20 PM
  5. subpanel ground rod location and installation
    By leejosepho in forum Electrical Forum discussion & Blog
    Last Post: 11-05-2007, 10:38 AM
