Results 1 to 6 of 6
Thread: boiler won't start
    DIY Junior Member American's Avatar
    Aug 2013
    New England, USA
    Default boiler won't start
    I push the red button - nothing happens. I push it again, it seems to start and then shuts off. There's oil in the tank.
    In the trades Dana's Avatar
    Jan 2009
    Model # & manufacturer? (Just a "red button" isn't much information to go on.)
    Nov 2010
    Maine
    It's an oil burner so the red button is the primary control re-set. Could be any one of many things. Plugged filter, oil line, pump strainer, nozzle
    Bad electrodes, transformer
    Bad oil pump, motor, pump coupling
    Bad primary control, cad cell eye, electrical issue and the list goes on and on. Call an oil burner tech.
    If it starts and there's no flame, best guess is bad nozzle. If it starts, has flame and then it shuts down best guess is dirty cad cell eye or bad primary control.
    At any rate, anything that gets done will require a combustion test after the unit is repaired to verify the cleanliness of the flame. Sooty fires plug heat exchangers and make a mess of your basement.
    Aug 2013
    New England, USA
    Okay. Searching for the tech's phone number now. Thanks.
    Aug 2013
    New England, USA
    The problem was a worn out burner coupling end. It had been stripped and was completely round rather than socket shaped. Fortunately it was an inexpensive part. The tech cleaned the boiler and replaced the filter while he was here. Worth the call. I would never have found it.
    Nov 2010
    Maine
    Ahhh yes, number 10 on my list.
    It's good to have it cleaned and set up for the season too.
  1. Replies: 28
    Last Post: 01-15-2014, 08:32 AM
  2. Power-vented Gas fired boiler won't start when its cold out
    By johngoldfinger in forum Boiler Forum
    Last Post: 11-07-2012, 12:29 PM
  3. A/C start-up intermittent start up issue
    By jp102 in forum HVAC Heating & Cooling
    Last Post: 08-01-2011, 03:13 PM
  4. New Gas boiler start up
    By mat in forum Boiler Forum
    Last Post: 11-26-2010, 08:13 AM
  5. Old mclain weil boiler with electronic ignition slow to start
    By patzeram in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-19-2010, 02:41 PM
