I have a question about the proper configuration for connecting 2 sinks to a single 2" waste line. I'm planning on using two seperate P-Traps with each line being connected to the Y using a 45 degree elbow, after a short horizontal run. Is there any criticality about where the lines connect to Y in relationship to the height of the P-trap? For instance, should the connection be made x inches below the trap or x inches above the trap or does it matter? Both sinks are being vented by a 1.5" line which connects to the top of the Y. The bottom of the Y connects to the 2" waste line.
Thanks for the help.
Rob
Rob
